Question about Dishwashers
Frigidaire fghd2433kb1 detergent won't come out of dispenser
5 Suggested Answers
  • 130 Answers
SOURCE: replacing detergent dispenser
take the door apart, the dispenser will pop out and you can rehok the new. make sure the seal is good
Posted on Feb 17, 2009
  • 1531 Answers
SOURCE: frigidaire diswasher detergent dispenser
the first thing to make sure is that the incoming water temp is at least 120 degrees.the next thing to do is check your water level and pressure when running if the water pressure is not high enough then you may have to replace the main wash motor.
if you do not think there is enough water in the bottom of the unit after it has stopped fillng add a few more cups to bottom and continue the wash cycle.
if there is no change in the performance replace the main wash motor
Posted on Mar 14, 2010
  • 148 Answers
SOURCE: my frigidaire fdb1100rhm dishwasher detergent
Check for correct water pressure to the dishwasher. Could be a restriction in the 1/4" water supply line.
Posted on Feb 01, 2011
heatman101
  • 43501 Answers
SOURCE: The detergent dispenser won't open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Aug 05, 2011
Gltf1670as1can you use powder detergent in ?
Good Morning Friend,
I understand that you want to know if you can use powder detergent in your Frigidaire washer, model# GLTF1670AS1. Below are the advised steps for the detergent dispenser of your washer.
• Add measured detergent to the detergent compartment of the dispenser drawer.
• Detergent is flushed from the dispenser at the beginning of the cycle. Either powdered or liquid detergent can be used. Note: Liquid detergent will drain into the washer drum as it is added.
• Low sudsing detergent is recommended for this washer. Use the manufacturer's recommended amount.
• If low sudsing detergent is not available, a reduced amount of regular detergent may be used. Because
reducing the amount of detergent may reduce cleaning, it is important to pretreat stains, sort carefully by color and soil level, and avoid overloading.
• Detergent usage may need to be adjusted for water temperature, water hardness, size and soil level of the load.
• For best results, avoid oversudsing.
Hope this is helpful.
-Best Regards-
WP
Jun 05, 2014 | Frigidaire Washing Machines
Soap dispenser not work
Hello Sean Radler - Confirm that water action is reaching the dispenser; water sprayed from the lower wash arm is directed at the dispenser, reposition any dishes that may be obstructing the water from reaching the detergent cup. Make sure items in the dishwasher do not prevent the detergent dispenser from opening (like tall dishes or cookie sheets). If these items do not correct the issue, there may be a problem with the detergent cup opening. Contact a professional to move forward accurately.
Jan 03, 2013 | Frigidaire 18 in. FDR252RB Built-in...
Detergent won't enter wash cycle
Clean the dispenser first and see if you noticed any blockages and then clean the unit itself in the dispenser area and use a little less than recommended and see if you notice any changes.
Jul 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (GLTF1040ASO) is leaking water by the detergent dispenser area. Any suggestions on what this could be?
This is usually caused by solidified detergent blocking the water ways in the detergent dispenser.
Check the inside of the dispenser to make sure the outlet holes are not blocked.
Most dispensers can be removed for cleaning check your appliance instructions for details.
Dec 13, 2010 | Frigidaire GLTF1040A Front Load Washer
Water won't drain out from the spots where fabric softener goes
It typically has some residual water after a load. All you need to do is to remove the detergent dispenser and dump the water out. To remove the detergent dispenser, pull it out as far it will go, then look into the detergent slot. There should be a horizontal plastic tab in the back of the detergent slot. Press the left side of the plastic tab and pull the dispenser out of the machine. Then you can dump the water from the bleach and fabric softener slots. Just slide it back into the machine and your good to go. Hope this helps.
Jul 12, 2010 | Frigidaire Washing Machines
Frigidaire diswasher detergent dispenser
Mar 14, 2010 | Frigidaire Dishwashers
Detergent trouble
hi there,
sounds like the detergent dispenser is not working properly.
are the rest of your dishes clean? in other words, is there any food residue on them?
check the dispenser and make sure that there is nothing visibly wrong with it.
if the problem still persists, replace the dispenser.
Mar 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
