Question about Euro-Pro TO285 1500 Watts Toaster Oven with Convection Cooking
Need a wiring diagram. - Euro-Pro TO285 1500 Watts Toaster Oven with Convection Cooking
Where can i get a diagram of a Krups FBC412?
Maybe Krups can provide the diagram if you inquire.
Aug 20, 2016 | Krups FBC412 1600 Watts Toaster Oven with...
Where to get wiring diagram
Not sure where you are but try this link: http://www.haier.com/us/ if you are not in the US you should be able to get to the country you want but the manuals should be the same except the language.
Nov 28, 2014 | Haier RTC1700 1700 Watts Toaster Oven with...
Bake no longer works
Kitchen aid will not help, will not sell the part and will not give you a part number for ordering.
the part that goes bad is one of the 2 piggy back function switches. it gets hot from electricity and deforms the plastic causing the connection inside to fail.
I traced all the wiring and made a schematic to use for testing. Kitchen aid refused to even talk about it, so what I share is from my own experience.
By the way, I could not find this part (fz31-9) other than in china and it has a specialized cam inside and 5 connectors. there are 8 that match and not knowing witch cam, makes it very difficult to guess.
the attach diagram worked for me, but it man made and could contain errors.
Mar 11, 2012 | KitchenAid KCO222OB Toaster Oven
Top heating bars stopped working
Dear Tang_Tuong,
I would check all of the fuses, the internal fuses and wiring for any signs of damage and that particularly from heat. Also multimeter the connectors of the wiring to the element and see if you are getting a voltage reading, if you get a reading from the wiring and the element is not heating up, then you need to replace that element, do these checks for all of the internal components and you will find the one at fault.
I do hope this is the fixya for you and look forward to hearing how you get on.
Yours sincerely
Ouszen
Feb 07, 2012 | Euro-Pro Toaster Ovens
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Blown fuse
You need to go to your local Harbor Freight Tools and pick up a security tool kit for $9.99 so you'll get the bits required to remove the special screws. You need to remove all the screws around the outer edge of rear and then pull the white rubber plugs out of feet and remove the screws from feet. Then the entire cover lifts off of unit. That exposes where the power cord enters the back of unit. You'll see a smaller black wire leaving that area going over to the timer knob. Before the wire gets to the timer knob, there is a sleve covering the wire. If you'll cut the zip tie holding all the wires together, you can slide the sleve (mine is red) backwards toward where the power wire comes into unit. That will expose the inline fuse that is blown. You will need to call Delonghi to order the wire. It is pressure fitted on. You should be able to pull the connectors lose by hand on each end. Simple fix!!
Dec 28, 2007 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Euro-Pro TO285 1500 Watts Toaster Oven with Convection Cooking Logo
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
