Question about Makita AF505 2" Brad Nailer
I have a Mikata AF505 brad nailer that won't fire. The idler does not depress the firing pin, but I can depress the pin with a screwdriver and a brad is ejected properly into a piece of wood. It worked fine the last time I used it, probably a couple of months ago. What could be causing this problem?
2 Suggested Answers
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
Mastercraft brad nailer model 57-7900-2 5/8" - 2"
No experience of Mastercraft brad nailers but if fires with out depressing nose tool is dangerous and should be returned to manufacturer. Dewalt make battery powered brad guns and recently produced a battery framing nailer. I would not say that other nail guns are exactly cheap if they are beware they may not be up to the pressures excerted on the whilst firing.
Jan 24, 2014 | Air Tools & Compressors
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
NEW BRAD NAILER ONCE LOADED WILL NOT WORK
Many modern brad and finish nails use a sequential fire trigger system. You have to push the nose of the tool down to depress the safety THEN pull the trigger. This is the opposite of how a bottom fire works where you hold the trigger and bump the nose to fire the gun.
Mar 02, 2012 | Air Tools & Compressors
Firing pin won't return SB 1842bn
Lubricate it and crank up air pressure and return spring.
Feb 14, 2012 | Stanley Bostitch Sb1842bn 18 Gauge Brad...
Tnt brad nail wont fire
If you hear a slight discharge of air from trigger area and no fire, could be a lack of lubrication of the headvalve or safety foot is not pushing in the firing pin. If the safety foot is not pushing the firing pin, examine parts and repair as needed. If safety parts seem to be working ok, remove the head and lube headvale with silicone paste or white grease.
Nov 06, 2011 | Sears TNT 3 gal Air Compressor with 2 in...
My braid nailer will not fire. I can hear air when I pull trigger but it will not fire, almost like it has a brad jamed in it but do not see one?
Most likely stuck driver or headvalve. Easy fix. Remove the head, pull out the driver and check for bent shaft, if ok, lube and reinstall. Next remove the valve within the head, lube and reinstall. Replace parts as meeded. Retest. If it still does not fire, could be that the safety foot is not pushing the firing pin all the way up into the valve. Easy to check. Remove the nails, remove the trigger to expose the firing valve pin. Dry fire the gun by quickly depressing the valve pin with finger. If it fires, adjust safety foot as needed. Parts are at www.toolpartsdirect.com
Nov 02, 2011 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Makita AF505 2" Brad Nailer Logo
85 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
