Question about Roper Dryers
Replace thermal fuse roper dryer model red444ovq1
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have a roper dryer model RED444OVQ1 an it wont start, i have replaced the thermal fuse and cycling thermostat, where do i go from here?
Door switch:
Posted on Oct 13, 2012
Dryer not work and i tink the motor is the problem and i want to how to tex my old motor
it may just be a thermal fuse located on the blower housing
Feb 25, 2013 | Dryers
Have a roper dryer model red444ovq1 that will not start. have checked door switch element,thermofuse,cycling thermostat high limit fuse the 249 volt circuit and every thing else that would normally ca
BE SHUR TO CK FOR 240 VOLT UNDER A LOUD PUT YOUR LEED ON LINE 1 AND LIND 2 AND PUSH STAR TO SEE IF THE 240 STAY. IF YES THEN YOU CK THE FUSE FOR CONTENUTRY AFTHER TAKING 1 WIRE OFF IF YES CK TO SEE IF YOU GET 120 VOLT TO THE MOTOR ON WAITE WIRE AND BLK OR BLUE IF YES THE MOTOR IS OUT IF NOT THE CK TIMER .
Feb 21, 2012 | Roper Dryers
Where is roper thermal fuse, its an older dryer
On older Whirlpool brand dryers(roper is made by Whirlpool) the thermal fuse is usually always in the blower housing..to get to it ya would need to remove the back panel.
This video shows who to replace the thermal fuse http://www.youtube.com/watch?v=aUQQJAxkZ0g
GENE
Sep 16, 2011 | Roper RES7646KQ Electric Dryer
Dryer won't start
This usually caused by a blown thermal fuse on the blower housing located behind the rear access panel. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Unplug the dryer or disconnect power then remove the rear access panel. Locate the thermal fuse then bypass it for troubleshooting purposes.
Bypass the thermal fuse by disconnecting the wires and joining it together. Insulate properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Clean the lint filter and make sure the vent system is not restricted then replace the thermal fuse including the cycling thermostat (thermistor for other models) as a standard operating procedure and preventive measure. The thermal fuse usually cuts out due to a failed cycling thermostat(thermistor for other models).
Jul 19, 2011 | Roper REX3614KW Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
I have a Roper dryer Model: RED444OVQ1 that won't turn on .
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 20, 2011 | Roper Dryers
Roper dryer movel RED4440vq1 drum does not turn. replaced motor, still not workking. belt is good. wiring harness is supplying 120 v on the 2 end red leads. door switch good. push to start button good.
The thermal fuse is likely blown. Disconnect power then remove the rear panel to access the thermal fuse on the blower housing.
Once the panel is off, bypass the thermal fuse by joining the wires together then insulate them properly. Reconnect power and start the dryer. The thermal fuse is indeed blown if the dryer starts. Replace it including the cycling thermostat.
Oct 15, 2010 | Roper Dryers
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Dryers Logo
24 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
