Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
Smart fortwo driver seat jammed - Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
Hi, how do I correct an error code C1446 for a 2011 Smart Fortwo 1L engine? Thank you!
Smart Fortwo C1446 Possible Solution : The crankshaft sensor signals the fuel injection computer or the ignition control when the cylinders are firing. This causes the ignition coil to provide a spark and the injector to inject fuel into each cylinder at the right time.If either sensor isn't working correctly, the car will run rough and the engine will be less efficient. In later car models, the car's computer can usually keep the vehicle running, but the engine warning light on the dashboard goes on to warn the driver
Dec 05, 2016 | Smart Cars & Trucks
Where is the smart car radiator fille cap?
You need to check under the top part of the bonnet in the front as the resevoir is located on the drivers side under the bonnet. smart Car Service Flap smart USA owners guide
May 21, 2014 | 2008 Smart fortwo
2006 smart fortwo coolant loss
Likely a blown head gasket, or cracked head, hopefully not a cracked block. Check the oil to see if it looks milky. Check the tail pipe to see if coolant is dripping out of it. If you can, check the compression in each cylinder. If two adjacent cylinders have low compression, it is likely a blown head gasket.
Mar 06, 2014 | Cooling System for Smart fortwo
Locksmith can unlock immobilazer?
Doubt that very much , as Smart has a very strong security on it
Feb 21, 2014 | 2006 Smart ForTwo Cabriolet
Smart fortwo door lock jammed
hi could b the short cable at the doorhandle the one tha goes to the lock one hex screw to remome handle should just need a cable there bad for snapping
Aug 02, 2012 | 2012 Smart fortwo
Is there a spare wheel with the smart passion
Spare wheel is an optional extra. if your car has one, it slides behind the drivers seat.
Nov 07, 2010 | 2008 Smart fortwo
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
13 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
