Ir8500 hiter & durm unit rotet but peper jam duplex in no indicet
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: paper jammed whilst duplex printing
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
  • 149 Answers
SOURCE: read out says remove the jammed paper from the
the duplexing unit is under the fixing feeder frame unit..... have only worked on one NP before and it was much like the IR5000 all you need to do is pull out the tray under the fixing frame assemble
Posted on Jun 14, 2010
SOURCE: false jamming at duplex unit
IT THE BIPASS ROLER THAT IS NOT PICKING THE PAPER
Posted on Jan 10, 2011
canontech
  • 1219 Answers
SOURCE: drum unit become jam and
If there is spots, lines and similar on drum surface, these means that you need to replace drum unit, because the drum cleaning blade, or primary roller, or drum is worn out.
Hope that helps!
Posted on Apr 27, 2011
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Sir my canon 2870 paper jam hiter and by pass get i want to help me solve the problem
Firstly you must know from which source paper pick up then first step you need to check pick up roller
Dec 09, 2011 | Canon imageRUNNER 2870 Copier
Hi, Hope you can help, A CP 6015 jams on dupex 2nd side on entrance to fuser,it looks like something to do with pressure roller release mechanisum as when released an actuator moves across fuser entrance,...
The document I was thinking of referred to fuser wrap jams. I did some quick checking of duplex jams though and this might give you some guidance to check for.
These errors refer to jams when repicking to print side 2.
Cause Solution The spring of the duplexing media-repickup-sensor lever is unhooked Check the spring and place it in the correct position. The duplexing media-repickup-sensor lever is damaged Replace the duplexing feed unit. Poor contact of the duplexing media-repickup-sensor connector Reconnect the connectors of the duplexing media-repickup sensor (J1945), intermediate (J1909, J1950) and the DC controller PCA (J4105). The duplexing media-repickup sensor is defective Check the duplexing media-repickup sensor by the sensor monitor mode. If the sensor is defective, replace the duplexing feed unit. Poor contact of the duplexing repickup-motor connector Reconnect the connectors of the duplexing repickup motor (J1771), intermediate (J1908, J1939, J1941) and the duplexing driver PCA (J4104). The duplexing repickup motor is defective Replace the duplexing feed unit.
Mar 10, 2011 | Office Equipment & Supplies
Hey I have installed a duplex unit in my canon iR2018 it was copying normally before I install it and now it is having paper jam after installing the duplex unit
did you properly conect the all connectors?
See instalation manual.
Maybe the duplex unit didnt set very well.
Where paper jam occurs?
Try to clean all rollers on duplex, maybe the unit were very long time stored badly.
Pls. give more info!
Jun 14, 2010 | Canon iR 2016i Black and White Copier
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Apr 01, 2010 | Minolta DiALTA Di183 Copier
Paper jammed whilst duplex printing
Sep 06, 2009 | Canon PIXMA MP970 InkJet Printer
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
37 people viewed this question
jasbo
jasbo
