Question about Digidesign C24 Pro Tools Control Surface
A fader not working on my c24 control surface degidisign 003 someone talked to me its the psu problem its that right?
Where can I get a 48v psu for a spirit folio fader 100?
Your best bet would be to go directly to Soundcraft support. Here is the link-
Where To Buy
Oct 02, 2016 | Spirit Music
Just got 1998 dodge 1500 van and the left front and the left rear speakers not working also the interior lights do not work the van came with a regency conversion package on it and some one has took the...
A silly suggestion but have you moved the right left fader control. If the control is on full right fade the left speakers will not be heard.. Faders work back and front and left and right.
Apr 01, 2013 | Cars & Trucks
I can't get my Behringer XENYX X1222 USB to control any of the faders within Sonar X1 Producer.
It may require the driver to be installed for the Behringer, or re-installed.
Go into the settings section of Sonar and if you can "De-select" M-audio as the default controler, or you may need to go through the preferences of M-Audio to find it.
To me it sounds like a driver is missing.
Jan 30, 2012 | Music
How hard would it be to change a fader control on a peavey escort 2000
Changing faders USUALLY involves removing all panel hardware so that circuit board can be removed to get at the fader. It is often a LOT of work with a boit of hazards along the way.
If the control is noisy I want you to try something before replacing the fader. Get a can of CRC226 available at Home Depot in the Electrical department... about $2.70 for a can. Using the included plastic spout tube, squirt a bit into the center of the control where the knob is. Work it back and forth and then put a little more in and test if it is better or fixed.
NEVER use DeOxit or Blue Shower in faders!!!!! It removes the lube that is required in the fader.
Jan 04, 2011 | Peavey Escort 3000 Packaged PA Speaker...
Faders not working properly on am844d right channell goes in out when I wiggle the main L/R fader. Some of the channel faders are eractic. The level of volume is not responding right to fader...
You probably wrecked the faders putting De-Oit in them!!! NEVER use that in pot and faders... It is for switch contacts only.
You have ONE chance to save them. From Home Depot get a can of CRC226 in the electrical dept. Put some of that using the spout into each fader near the middle and work the faders. The CRC226 costs about $2.70 a can. Make sure it is the 226 as there are OTHER CRC products there and only 226 is the one that is suitable.
The De-Oxit will have cleaned out the lube of the faders and if you are unlucky, one or more of the wipers will have folded back which is fatal... The CRC226 is an electrical lube that I have restored faders and pots with... It has many other uses including lubing plier joints...
Dec 31, 2010 | Phonic Am 844d Mixer 8 Mic/line 4 Stereo 4...
Use of the radio: i like more the music coming from the back of the car.
Thats controlled by the fader, you can adjust front to rear levels.
Balance is left or right.
Nov 24, 2009 | 2000 Chevrolet Blazer
InFocus LP600 Projector power source failure.
if you got a display or even just an led, it's not the power supply, it's the main board. if you get a start display but no light, it's the ballast. even if it is the power supply, it's only $80 from an authorized service center.
Jun 09, 2009 | InFocus LP 600 Multimedia Projector
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Pc speakers will not play on my computer
1-confirm that you put it in right place(almost green socket).
2-right click in speaker icon and open volume control.
3-confirm that volume control fader is in up position and not muted.
4-check all faders are up and not muted.
5-you must confirm first that your speaker is ok first(try with another speaker)
Jul 04, 2008 | Audio Players & Recorders
The devise does not hear my voice what should i do?
The first step is to go into your volume control panel and check to be sure that the microphone fader is not muted and is turned up. Also, what application are you attempting to talk to someone with -- telphone, IM chat, game chat?
Apr 12, 2008 | Labtec Desk Mic 534 Consumer Microphone
Digidesign C24 Pro Tools Control Surface  Logo
43 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
