Question about Hotpoint HTS16BBMLWW / HTS16BBMLCC Top Freezer Refrigerator
Food area freezing
I changed the temp control and i still have the same problem
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Try adjusting the air damper. also how you arrange the shelves and food can have an effect on how things cool. think of the cold air from the freezer as a water fall. if tall items are causing the air to channel straight to the botom of the fridge with out dispersing it will cause items to freeze at the bottom of the fridge. Play with your lay out. Also if the fridge is running all the time good way to test is to turn the fridge all the way up before bed. in the morning if the fridge is still running try turning it down till the compresor turns off. if the control is in the off position you need to replace it. if it shuts off before the control says "off" play with the air flow. Hope this helps.
Posted on Sep 27, 2007
SOURCE: fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Posted on Nov 12, 2008
  • 220 Answers
SOURCE: GE GSS25LGMA WW FREEZES FOOD
These refrigerator use the cold air from the freezer the cool the refrigerator. At the rear of the upper refrigerator compartment, there is a shroud. Remove the shroud and you should see a "flapper" that shuts off the cold air when desired. You will most likely see the flap is broken. Once the flap is broken, you lose control of your refrigerator temp. This is a common problem with this refrigerator.
Hope this helps.
Posted on Jan 11, 2009
SOURCE: PSS25S side by side is freezing vegetables. We
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer runs constantly. food freezes in bottom
I see this happen a lot on these models. The defrost control board is part of four operations. If you changed the Defrost control board then one of the two thermostats is not responding to changes in temperature settings. For freezer if turning the thermostat warmer should cause the compressor not to run as much and open the damper and regulate. If the only place the thermostat setting is placed to off and it responds only to off I would believe that thermostat is the reason. I believe you are on the right track to repair but if you have a look at the wiring diagram you see the connection and point I'm trying to make here. Let me place the diagram and send you a link shortly, Thanks, Sea Breeze
Posted on Feb 20, 2010
wiqi546
  • 1511 Answers
SOURCE: fridge area freezing foods, thermostate
Hello and Welcome to FixYa!
The problem you are facing is due to one of the following reasons:
If the thermostat is at its maximum warmest temperature and still the things are freezing up, it shows that the thermostat could be faulty and needs to be serviced/replaced.
If the thermostat is not the bottle neck then there is a possibility of a leak in a sealed refrigerant system or cold air migration unit (In Side by Side models) or the worst due to the Air Damper.
Actually the bottle neck to the symptoms you are facing is a bit tedious to locate. Actually it requires a very detailed physical analysis of the above quoted components that might require the services of a qualified repair person.
Best of Luck,
Please do Rate the solution, If you feels this helps you,
Concerned.
Posted on Aug 10, 2010
Produce freezing
Is their a thermister in the fresh food area? Does this one have electronic controls? If so it measure temps with thermisters. The resistance measurement monitored by the control is what tells the control to turn the compressor on and off. Might be a bad control also. Impossible to give a good answer without a model number.
Amana bottom mount service manual and more can be found HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 24, 2012 | Amana Refrigerators
My fridge is freezing food
HI,IF YOU REFRIGETOR IS FREEZING FOOD CHECK YOUR TEMP CONTROL OR THERMOSTAT AND THE AUTODAMPER (airflow control) PROPERLY CONDITION,,IF THE TEMP CONTROL IS BAD THE COMPRESSOR WILL BE WORKING ALL THE TIME,IF THE AUTODAMPER IS BAD WILL BE COOLING TOO MUCH..
Feb 21, 2011 | Refrigerators
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Temperature regulation not working (max only), water dispenser not working and ice maker not working although dispenser works
The symtoms sound all to common on GE units. Based on your symtoms I suspect the fresh food area is to cold. The damper assy is controled by the motherboard / thermistors. This damper assy adjusts to control the air movement from the freezer. During its cycling it can snap loose when this happens the air from the freezer is uncontroled. Within a few days the fresh food compartment temps can drop below freezing. The drop in temp also can freeze the water reservoir behind the lower crispers and in some cases the water filter. Altho You may have other issue (i.e. filter, bad fill valve assy, motherboard) the above statement happens 70% of the time. Fresh food damper assy part# WR49X10091 est $135.00.
Ric
Mar 09, 2010 | GE GSS25LGM Side by Side Refrigerator
Sep 12, 2009 | GE Profile¿ Arctica® Energy...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Freezing fine,food area warm
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Hotpoint HTS16BBMLWW / HTS16BBMLCC Top Freezer Refrigerator Logo
79 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
