Question about Cell Phones
Samsung factory reset e8000 - Cell Phones
Factory resetting my Samsung Galaxy S7
hi Linda.
How to factory reset the Galaxy S7
  1. Swipe down from the top of the screen to pull down the Notification Shade.
  2. Tap the Settings button. It looks like a gear.
  3. Swipe up to scroll down on the settings screen.
  4. Tap Backup and reset.
  5. Tap Factory data reset. ...
  6. Tap RESET DEVICE.
  7. Tap ERASE EVERYTHING.
How to factory reset the Galaxy S7 ' Android Central
https://www.androidcentral.com/how-factory-reset-galaxy-s7
to read up more you could go to this link.
how to Factory resetting my Samsung Galaxy S7 Google Search
Nov 26, 2017 | Samsung Cell Phones
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... www.verizonwireless.com > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube www.youtube.com/watch?v=nZBZYa4nZ18
    • BY ASKTHEANDROIDGUY
    • 3 MIN
    • 110K VIEWS
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: http://www.RickytheAndroidGuy.com Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... www.hardreset.info/devices/samsung/samsung-t330-galaxy-tab-4-80 Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... solverbase.com/w/Samsung_Galaxy_Tab_4_8.0:_Hard_Reset_Factory_Reset Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages www.technipages.com/galaxy-tab-4-hard-reset How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
  • https://www.android.com/tablets
    May 23, 2016 | Samsung Tablets & eReaders
    How do i restore system factory settings on a samsung R50 PC
    Method one:
    <1>. Press and hold on Esc key, and then start Samsung laptop
    Note: Please don't loosen your hand on Esc key until the Samsung laptop starts with restore system.
    <2>. Find Samsung Recovery Solution program, and run it. Or Enter Menu window.
    Note: Samsung Recovery Solution is system restore program provided by Samsung. Used for Samsung password recovery etc.
    <3>. Press F11 to restore Samsung factory setting.
    Method two:
    As we all know, Samsung laptop is taken with one function that Samsung factory reset with one key. Just start your Samsung laptop and press F4 or F7 at the same time. And Samsung laptop will run system restore program automatically.
    May 21, 2016 | Samsung Computers & Internet
    How can i find id , and password for samsung account? i have forgotton it
    Click on the forgotten ID or password link from this samsung account website and reset your details.
    Services Samsung Account
    May 09, 2016 | Samsung Galaxy Grand Prime G530 Factory...
    Hard reset samsung sgh
    Samsung T499 Dart Android hard reset
    1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
    phone. Reset
    2. When the Android System Recovery screen appears, release the keys.
    3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
    4. Press the Power key to confirm.
    5. With Volume select Yes -- delete all user. Press the Power key to
    confirm.
    After master reset select Reboot System Now. Press the Power key to confirm.
    6. Your T-mobile Samsung Dart phone reseted to the factory default state.
    (This should work but if not, try both volume + power)
    Samsung T-mobile Dart reset
    A Samsung T499 master reset restores the original factory settings and
    may erase all downloaded content, including ringtones, images, programs,
    and contacts stored in the internal memory. It does not erase data
    stored on the SIM card or memory card (if available).
    To perform a hard reset, follow these steps.
    Samsung Dart T499 Factory Data Reset
    From this menu you can reset your phone and sound settings to the
    factory default settings.
    1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
    Samsung Dart T499 reset settings key (Settings) - Privacy.
    2. Tap Factory data reset. This action erases all data from your phone
    except current system
    software and bundled applications, or SD card files such as music or photos.
    3. Tap Reset phone - Erase everything.
    Samsung Dart Password code try 1234
    or
    Use this method to hard reset your Samsung Dart Android phone: Enter
    *2767*3855#. Warning! All your data including contacts, messages etc.
    will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
    or make backup to your PC before full reset! Take out SIM card before
    full reset.
    Jul 24, 2014 | Samsung SGH-T499
    Text message wont open on e8000
    I had to delete everything in the inbox including unread message. Not a great solution but at least it works!
    Apr 22, 2008 | Samsung Lands Phones
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
