Question about Fujitsu LifeBook S6240 Notebook
Flashing lock symbol
Flashing
Flashing key symbol
wire may have fallen off switch, or shorted
Feb 08, 2013 | Hotpoint WMA74 Front Load Washer
Won't start key symbol flashing
So do you need a manual for operating it ?
Oct 06, 2008 | Gaggenau EB290 Electric Single Oven
Cranking but not starting...
If the pass lock sign is flashing (pad lock symbol) then you have no gas to start, you have to turn the key off, wait ten minutes then see if your pass lock symbol light goes out, it will blink then go out if it is reset, then you can start your engine.
Dec 20, 2012 | 2005 Chevrolet Colorado
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Please describe your how can i do remove the witeprotecion of flash drive problem
Flash and USB drives usually have either a mechanical switch or software that can lock the drive.
If your drive has the switch, slide it to unlock. If it is software, follow the instructions in the help file on the drive. The drives are not supplied locked by software.
If the Flash Drive has been locked using Bitlocker, the only way to unlock it is to input the password set at the time it was locked, as with software locks.
Mar 08, 2011 | Computers & Internet
What does car with lock symbol mean
This symbol is usually your security light it flashes when the vehicle is locked. It comes on solid and goes out after it recognizes the key. And it flashes fast when it thinks it's an invalid key
Jan 19, 2011 | 2009 Hummer H3
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Small lock symbol on 4GB transcend pendrive
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Sep 12, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Lock symbol on oven won't go away
Unplug for 60 seconds and plug back in
Apr 30, 2009 | Ovens
Nikon Speedlight SB-800
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Nov 16, 2007 | Nikon Speedlight SB-800 TTL Flash
Fujitsu LifeBook S6240 Notebook Logo
35 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
