Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Panasonic viera 37"
My panasonic viera 37" when i turn it on you can hear the chanel but the screen is black and it says "ec1" at the top left hand corner,what do i do to get ec1 off and see the chanels picture again
  • 1 more comment
  • Anonymous Mar 15, 2014
    i have a panasonic flat tv i can only get small picture in top left corner
    i have a flat screen panasonic tv i only have picture in top left corner
    i only have a picture in top left corner of my flat screen panasonic tv
... the problem was presenting when switching on the tv... the temporary solution was to press the a/v button, hope this can help
Posted on Oct 03, 2007
I solved it switching on and off the satellite cabled on scart 1, it was like it sent some strange bits of activity, even though being turned off
Panasonic viera black line split screen horizontal 3/4 left 1/4 right
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 08, 2012 | Televison & Video
We have a sound symbol with a red cross through it in top left hand corner appear don't know how to turn it off
Use the remote to disable it, it is the sign of mute press the mute button in the remote. Good day and best regards.
Sep 11, 2011 | Panasonic Viera TC-L37S1 37 in. HDTV LCD...
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Had Sky installed. Displays EC1/RGB on left hand
Double clicked the i button on the TV remote - simples!
Jan 11, 2010 | Panasonic TX-32LX60 32 in. LCD Television
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Black box in top left hand corner of screen won't go away
It sounds like you are in Closed Captioning 2 mode. Check your setup menu. Turn off or choose mode 1
Nov 19, 2009 | LG 37LH30 37 in. LCD HDTV
Some stations do not come in full screen?
Not all programmes are broadcasted in a full screen format, they may show the programme with black bars on the top & bottom or left & right sides of the screen. If you have the TV in the Auto setting for the Aspect Ratio then the picture will be displayed in that size of format relative to the broadcast. If you want to fill the screen you can try a different Aspect Ratio to one that fills the screen to a wider image if available.
Sep 10, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Top left corner of screen is black about 3
Do you have a PIP (picture in picture) button on your remote? Could that be it?
Mar 04, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
581 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
