Logik Problems
Logik 500gb freeview recorder L5SSTB12 display panel says Hdd and the box will not work,this has happened before - it sometimes freezes so I unplug the power and restart,sometimes successfully,sometimes it wont though and it just shows 'Hdd' in display panel
SOURCE: Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Posted on Oct 29, 2007
  • 67 Answers
SOURCE: Problems using video to record from tv
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Posted on Nov 14, 2007
SOURCE: thompson dti6300 twin freeview box with 160 gb hdd.
When box freezes turn box off at wall for 30 seconds then turn on again, when red light comes on carry out the following.
  1. Press menu
  2. Press 4
  3. Press 6
  4. Type in 1397
  5. Scroll down to item 7
  6. Move across to change to yes
  7. Press library
  8. Highlight corrupt program
  9. Press blue then green
  10. It can take quite a while to delete
  11. Press back to come out of menu as to need to follow this procedure for each corrupt program
Posted on Jul 24, 2008
  • 3 Answers
SOURCE: my tevion universal 8 in 1 remote won't work any tevion devices
tevion is made by konka, try using konka tv settings.
Posted on Feb 21, 2009
SOURCE: Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Posted on Mar 04, 2009
The HDD is no longer seen by the system, can't access media library etc. Is there any way of testing if this is an HDD failure or system board issue.
You may have a loose wire or one that's not making good connection. unplug all wires going to hard drive, then reconnect them. Also make sure the plugs to the motherboard is secure. I have this same problem with my pc from time to time.
Aug 25, 2015 | Humax Hdr-Fox T2 500Gb Freeview Hd Digital...
My logik freeview box is reading hdd,what does that mean and how do i fix it.
prob the internal hard disk drive has failed
replace it with a nice new sata 500GB type
will cost you about £25 from ebay
you could try to 'format internal drive' etc in the menu
perhaps its full or corrupted
most often its defective
Dec 02, 2014 | Televison & Video
My Logik freeview box has will not tune some channels - most are fine. What can be done to fix this?
Usually that is caused by poor signal strength or a faulty tuner inside the receiver. Replacement boxes are only £18 upwards.
Nov 23, 2014 | Televison & Video
How to reset the pin for Panasonic DMR-HW120EBK 500GB HDD Recorder with Twin Freeview +HD Tuners (2012)
This is the definitive answer from Panasonic Customer Services. It worked for me.
In response to your enquiry, I am writing to inform you that you can reset the PIN number to the default 0000 and then change it, based on your preference. In order to reset the PIN, please follow the next steps:
1. Switch ON the unit;
2. Press and hold the OK, YELLOW and BLUE buttons, at the same time, until you see 00 RET displayed on the unit;
3. Press, repeatedly, the RIGHT ARROW buton until you see 03 VL;
4. Press OK and you should see "INIT" displayed on the unit.
This will reset the PIN number to the 0000 factory preset.
Furthermore, you should also be able to remove the message that is asking you for the child lock PIN while attempting to play back a recording. In order to do this, please follow the next steps:
1. Press SETUP;
2. Choose HDD/USB HDD;
3. Select CHILD LOCK FOR PLAYBACK;
4. Input the default 0000 code;
5. Switch it to OFF.
After performing these steps, the recorder should no longer ask you for the PIN when trying to playback a recording.
I trust that the above information will be of assistance to you. However, of course, if you should have any further queries, please do not hesitate to contact us.
Kind Regards,
George
Customer Service Team
Panasonic UK
Feb 19, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Digi box is displaying fail
AFTER SEVERAL POWER CUTS WE ALSO HAVE FAIL ON OUR BOX ANY IDEAS HOW TO RESET IT , I UNPLUGGED FOR NIGHT TO SEE IF IT WOULD HELP BUT NOTHING ANY IDEAS DNT WANT TO LOSE ALL MY RECORDINGS IF I CAN HELP IT THANKS
Feb 06, 2013 | Bush BTU500DTR 500GB Twin Tuner Freeview...
My VCR/DVD, freeview box and non digital tv will show prerecorded video and DVD but will not record (or if it has it will not display). Could it be that the set up is not wired up correctly? The freeview...
Unless the Freeview box has two tuners then your going to have problems anyway when you want to record something and watch the non-digital TV at the same time. The solution is simple get another Freeview box (they are around £10 at the moment on E-Buyer.Com) get a box like this:
grubhead_17.jpg Available on Amazon (Scart switching box). This plugs into the TV or you can connect via one of the freeview boxes. Whatever works best.
The VCR has the other Freeview box connected to the second scart. (select AV2 when setting the channel to record and set the box to the channel you want to record) the first scart from the VCR plugs into the above box. When you want to watch press the switch.
By the way if the VCR has PDC on it set it to off, as it no longer works with digital.
Aug 21, 2011 | Televison & Video
Hi just received a 2nd hand dvd recorder with hdd and freeview, but it has no remote control. i have a universal remote, but don't know how to find a program code for it , can you help
Have one code for Logik DVD which is 3078. Also two codes for Logik VCR (which might work) which are: 1179 and 1220.
Hope that helps!
Mar 01, 2010 | Televison & Video
Connection problems.
Must be connected by now I guess :)
Dec 14, 2007 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
