Question about Husqvarna Zero Turn Mower Z5426
Runs but will not move - Husqvarna Zero Turn Mower Z5426
My engine overheat when A/C is running on a slow moving traffic or on parking.
I would check and see how much air is actually moving thru the radiator. The fan may not be running fast enough or you may have debris blocking the air flow. Also make sure the system is full of coolant and no air pockets.
Nov 03, 2015 | 1995 Jeep Grand Cherokee
Car runs will move in all gears but does move
This does not seem like a problem. Selector moves, vehicle moves, what is the question?
Aug 30, 2014 | Cars & Trucks
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Antenna motor runs but antenna does not move ate
Hi Carl.,
If the antenna motor runs and the antenna does not move out, then there is something wrong inside the antenna unit. Replacing a fuse will not solve the problem. Change the antenna unit.
Good luck.
Aug 06, 2013 | Cadillac DeVille Cars & Trucks
2004 tundra windshield wipers don't move but motor runs
If both wiper arms move, the linkage between them probably is OK. What isn't OK is the connection between the arms and the motor. You will have to get access to the motor area to find out what needs repair
Dec 27, 2012 | 2004 Toyota Tundra SR5
My truck wouldnt move so i looked at the torque converter while it was running and it is barley moving. how do i fix it?
i was at stop sign i move little bit my truck stop moving and truck was running.. i try to put it in drive wont move i also tryed other gears wont move at all. any one help me out?
Mar 20, 2011 | 1988 GMC K2500
Motor runs but chain does not move?
Check the chain drive sprocket to see if it moves when the motor runs. If not, there may be a sheared key between the shaft and sprocket or the teeth on the sprocket are badly worn off. Hope this helps!
Dec 22, 2009 | Garden
I have a ford escape 2001 v6,water was fulled in the tank
if it runs without overheating issues but doesn't move forward or reverse....check your transmision fluid level...if its too low the vehicle won't move but the engine will run just fine.
Jan 16, 2009 | 2001 Ford Escape
Husqvarna Zero Turn Mower Z5426 Logo
14 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
