Question about Sanyo SCP-3100 Cellular Phone
KEYS WON'T WORK
Recently, my phone's battery went dead. I placed it on the charger for a few minutes and it worked fine. Some of the keys were slow in responding, but other than that, it was fine. Well, the phone went dead again shortly thereafter. Even upon recharging the phone, the keys are not responding. I can't power the phone off, press any numbers or even view any of the 180 numbers I have programmed in my contact's list. Any suggestions??
  • 8 more comments
  • kaznz Dec 13, 2007
    None of the keys will functin on my Sanyo 3100 so unable to use it or even power off. It beeps randomly sometimes as single beeps, multipes and even in different tones ... does anyone have a solution please?
  • Anonymous Dec 25, 2007
    phone sucks
  • KBOCK Dec 28, 2007
    SAME PROBLEM THIS PHONE IS DRIVING ME INSANE NONE OF THE KEYS WORK!! @ALL SO STUPID ANY ONE WITH ANY SUGGESTIONS?
  • Anonymous Jan 08, 2008
    My sanyo 3100 was working fine and then the keys stopped functioning. When I flip it open and push the End key it starts up, finds serving and shows the icons on the screen, but none of the keys will do anything. I can't turn it off with the End key either. The side key works when the cell is flipped open for recording - thats it.I also thought maybe the keys were locked, but I can't get to the menu button, so how would I change that? Any other suggestions.
  • Kenneth Pruett May 10, 2008
    Same problem. I don't understand the answer "lock keys". Does that mean that the keys are locked? If so, how do you unlock them?
  • Anonymous Jun 08, 2008
    Phone was working fine then all of sudden none of the keys worked. I took it to a repair shop and they said all they did was clean the keypad and it worked fine for a day. Then the same problem, none of the keys work.
  • biggage76 Jul 15, 2008
    I have the issue of the keys not working as well. One day they stopped working and I took the battery out for a couple of minutes and they started to worka again. A few days later same issue but this time no keys other than to record a memo works and even that is sporadic. I am at least trying to get to the 212 phone#'s on there before I replace the phone, if necessary. Someone help PLEASE!!!
  • danmcgroarty Aug 04, 2008
    same water then no key response
  • kellyo21 Sep 05, 2008
    My husband's phone has the same problem, the keys just stopped working with no explanation. Our 4 y/o was able to get it to work for a day, but that was it. He can answer the phone only if he pushes the speaker button, then pushes it again to hear it in the handset. Can't dial out, can't text message. Sprint says they can't fix it.
  • MimoNay Sep 11, 2008
    ah yeah my phone got a droplet of water and now the keys won't work except for the record button on the side!!! PLEASE HELP!!!!!!!!
Lock keys
Posted on Oct 13, 2007
SOURCE:
My 97 accord has always ran with no problems. I recently replaced the battery and it started and drove fine for 3 months. After not driving it for 1 week, the car is dead, not even an inside light and...
If the battery is completely dead, you'll need to slow charge it for a few hours before trying to use a jumper battery. And you could have something shorted to ground in the car that drained the battery in the first place.
Try disconnecting the battery cables and using a battery charger to bring the battery back to life first.
Jan 26, 2014 | 1997 Honda Accord
WX 435 Motorola was working fine a few minutes ago then it just off and won't come back on or charge. What happened?
Sometimes if the battery is dead you need to leave it plugged in for 5-10 minutes before it will "come back to life"
If that doesn't work, unplug it, take the battery out, wait a few minutes, then put the battery back in and let it charge for a while.
Also try another charger.
Nov 13, 2012 | Cell Phones
Won't start properly
could be the starter relay .
Nov 02, 2012 | 2000 Ford Taurus
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
Phone completely dead
This is a very odd problem with an even "odder" solution. When this happened to mine, I found a website that told me the following. I swear it works... eventually... probably.
Take the back off and just set it aside for a few minutes.
Now, remove the battery, and then put it back in, and then press the power button. If that does not do it, repeat the process...
... like 20 or 30 or 40 times. Eventually, the unit will make a (scary sounding) "pop" noise, and should turn on as normal.
I have had 3 Tilts. (I tend to be hard on phones.) Of those, two have had the "death" issue. Both were resuccitated this way, and worked just fine afterward.
Best of luck! Hope that helped. :-D
Jun 21, 2008 | AT&T 8925 Tilt Smartphone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Phone suddenly stopped working
The rechargeable battery may be failing to recharge.
Dec 17, 2017 | LG Radio Communications
Sanyo SCP-3100 Cellular Phone Logo
98 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Steve Allison
Steve Allison
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
