Question about Electronics - Others
Motomaster 300a mobile power pack - Electronics - Others
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 2 in 1 spotlight/lantern power
I am looking for a charging cord...I moved and haven't seen it in a while. Is there somewhere i could buy one.
Dec 02, 2013 | Eliminator MotoMaster Mobile Power...
My motormaster eliminator mobile power pack 700A just started beeping. What is wrong with it?
if there is a car fuse, under the cover, remove it.
most of the time, it is only use to activate the LOW Battery alarm.
Put the fuse back, when fully charge.
Jul 10, 2011 | Eliminator MotoMaster Mobile Power...
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Electronics - Others Logo
24 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
