Question about Craftsman 1 hp Air Compressor, 4 gal. - 16638
Took apart air pressure switch model lf10-4h. Can't reassemble
Mac air ratchet repair diagram
What is the model number of the tool
Dec 05, 2013 | Air Tools & Compressors
I have a Makita MAC2400, it stopped working, didn't realize where the reset button was, took apart the on off switch thinking there may be a fuse, the spring made it all fall apart as soon as I took the...
The pressure switch is assembled by automation and is basically impossible to put back together by hand. Even if you did manage to get it back together, the adjustment if critical. Easier to replace with generic pressure switch. Order from ebay for about $15. Just pay attention to port size and cut-out pressure. Select a switch that has on/off ,several ports on bottom and cut-out from 125 -135 psi. Factory switch is too expensive and really not any better. Good luck
Sep 04, 2013 | Makita MAC2400 Electric Powered Air...
How do you re assemble the m74dp airsoft gun
I took apart the gun and cannot figure out how to reassemble it
Apr 23, 2012 | Air Tools & Compressors
Willnot shut off keeps gaining pressure,leaks from under switch box as its running dont leak after you unplug it
On my compressor, the pressure switch has a diaphram that moves with increased pressure to push the switch off. If yours is the same type, and the diaphram has a hole (maybe the leak you hear), it might not move far enough to push the switch off. Something to check. If you take the pressure switch apart, beware as there are springs and parts that will become instantly liberated, and they're difficult to reassemble.
Jun 23, 2009 | Air Tools & Compressors
Mr heater 75,000 btu kerosene heater
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Feb 27, 2008 | Mr. Heater MH75KT
Repost of A70 Mode Switch Problem
Make sure that the mode switch on the cover is in the playback position. Unfortunately, I don't have a source for new switches.
Apr 24, 2007 | Canon PowerShot A70 Digital Camera
Craftsman 1 hp Air Compressor, 4 gal. - 16638 Logo
44 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
