Question about Home Security
Clik2u no longer accepts pin code - Home Security
My iPhone 4 has been disabled.I am unable to enter an acceptable pass code. The pass code initially entered and subsequently discontinued will not be accepted by the phone.How do i restore my phone?
the pin number has been incorrectly entered more than 3 times so now you will need a PUK code to get back to the PIN code
PUK codes are only available from the service provider so ring them on another phone , provide proof that you own the account and they will give it to you
Oct 20, 2017 | Cell Phones
What nokia c3 pin code?
Hi. What kind of pin code are you asking for your Nokia C3? If it is a security pin code, it must be 12345 or 0000. If it is a network unlock pin code, you can visit Unlock-Zone.com and get it at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Nokia C3 with a NOT ACCEPTED SIM Card.
2 - Your phone should display 'SIM Restricted'.
3 - Press OK.
4 - Using the full qwerty keyboard, compose the code as #pw+CODE+1# and press OK.
Note :For Nokia C3 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Press OK.
4 - Using the full qwerty keyboard, compose the code as #pw+CODE+7# and press OK.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Nokia C3 is locked to.
The CODE you need to enter is the unique unlock code for your Nokia C3
Oct 14, 2014 | Nokia C3 Cell Phone
Radio wont accept correct pin no
there could be a couple of reason why it wont accept the radio pin.
Its possible that the radio pin you have is the orginal and maybe at same stage there was a fault with orginal radio and it was replaced under warranty the code wasn't updated .
Other is the bcm has been changed the codes hasn't been updated .
Jul 07, 2014 | 1998 Holden VT Commodore
Sony Ericson X8 got new unlock codes but cant get phone to accept?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Nov 05, 2012 | Sony Ericsson XPERIA X8 Cell Phone
I have a motorola w755 hwa phone, it is no longer with a service provider, but i need the contacts from the phone, and the phone is locked and won't accept code.
sylvan
You're likely out of luck unless you can push menu on pin screen to get security screen and then enter 000000.
Mark
Motorola Support
May 10, 2011 | Motorola Mobility MOTO W755 Cellular Phone
I want to know the international colour codes for wiring a three pin plug please
The colours vary from country to country.
In the UK and Ireland the colours are
Brown = Live, (Goes to the pin connected to the fuse, on the right if the longer, earth, pin uppermost)
Blue = Neutral (Goes to the pin on left if longer, earth, pin is uppermost)
Green and Yellow = Earth (Goes to the longer pin)
In the USA and Canada
Black = Hot (Goes to the pin on right when the long round,earth, pin is nearest the floor)
White = Return and (Goes to the pin on Left when the round, earth, pin is nearest the floor)
Green = Earth (Goes to the longer round pin)
Oct 20, 2010 | GPS
My phone is disabled + i cant fix it.
Well... PUK code has only 10 time to try. So hope you didn't use all 10 attempts. When PUK code is accepted simply type NEW pin which could be any combination of four digits. You can use your old PIN if you like.
Rate me if it helped. Thanks.
Apr 13, 2009 | Cell Phones
Pin number
The pin number for pairing every bluetooth is 0000.
I hope that solves your Problem, If so kindly accept it.
Thank You,
Arjun.
Apr 10, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Home Security Logo
27 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
