Honeywell rth2310b the fan is running but not cooling
  • 833 Answers
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Posted on Nov 13, 2008
  • 96 Answers
SOURCE: Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Posted on Feb 01, 2009
billyvangogh
  • 108 Answers
SOURCE: how do i install a honeywell rth2310b with an old
Run the old thermostat wires to R&W or RH&W on the new thermostat
Posted on Oct 27, 2009
FixinFax
  • 3085 Answers
SOURCE: I lost my RTH2310B manual
http://customer.honeywell.com/techlit/pdf/69-0000s/69-2229ES.pdf
Posted on Nov 07, 2009
SOURCE: Had electrician install RTH2310B Honeywell
check to make sure that it's wired correctly. R(red)power, G(green)common, Y(yellow)cooling, W(white)heating, O(orange), E(emergency)heat. Make sure that you have the correct thermostat because there is a heatpump thermostat and there is an air condition thermostat and they are wired differently.
Posted on Nov 27, 2010
Testimonial: "Thanks for the info but they appear to wired correctly so I will just check again. Thanks!"
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
Honeywell rth2310b 5-2 day is not working. light stays on and buttons dont work, how can i fix it?
Honeywell has a help line They have access to all of their codes and understand your problem. Google them for the phone number.
Sep 01, 2014 | Honeywell RTH2310B 5-2 Day Programmable...
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
Rth2310b wiring
More than likely, this is what you have:
Red- Power- (RC/RH)
White- Heat- (W)
Green- Fan- (G)
Blue- Cool- (Y)
Usually, the only times you need more than 4 wires are:
1. You have a HeatPump system.
2. Your new digital thermostat does not use batteries, which then you have to have a common wire to power the thermostat.
May 26, 2012 | Honeywell Rth2310b 5-2 Day Programmable...
Installed a RTH2310B to replace an older model honeywell. All wires do not match. only 3 do r, w1, and g do and o and e do not. what should i do?
The Honeywell RTH2310B is a standard thermostat and is not compatible with a heat pump system. The terminals O and E are for a heat pump system. I am assuming that the terminals you described that do not match are from the old thermostat. What you will need to do is get a heat pump thermostat. Sometimes it can be hidden within a lot of other descriptions on the front of the box, but it will say heat pump and either 2 heat/1 cool or 2 heat/2cool. You should just need the 2 heat/1 cool heat pump thermostat. Hope this helps.
Aug 17, 2010 | Heating & Cooling
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
I'm trying to install a Honeywell RTH2310B programmable thermostat. I only have 3 wires coming out of the existing thermostat (the red wire was attached to both Rc and Rh terminals). The other wires were...
Your house might be older.  Are your receptacles two-prong, or three?
I would ignore the missing "G" wire, and connect Red to both Rc and Rh, and Y to Y, and W to W.
Jan 01, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
