Question about Pinnacle Inertia Baitcast Reel
How to take apart and clean - Pinnacle Inertia Baitcast Reel
How do I clean or fix sticky keys (keys that take a lot of pressure to depress).
Most keyboards can be taken apart easily and cleaned with alcohol. remove the screws from rear of keyboard and it will come apart being careful with the keys not falling all over. if its a laptop they are difficult to clean because you cant take the board apart. you can remove keys and clean with Q-tip.
Feb 11, 2016 | Apple Usb White Keyboard A1048 - Spanish
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Take apart handset to clean keys
The handset keys may not be accessible for cleaning.
Jan 07, 2014 | GE Lands Phones
Where can i get kitchen shears that come apart so that i can clean them easily?
You can probably find come-apart shears in cookstores and kitchenstores because most professional kitchen shears come apart for better cleaning.
If you want to get them online, tho, I found these on amazon:
http://www.amazon.com/Wusthof-5558-1-Come-Apart-Kitchen-Shears/dp/B0000631ZM
Oct 17, 2013 | Home
How do i clean it ? Do I have to take it apart?
To clean it, you will need a small paint brush, screw driver either flat or crossed, then disassemble it.
Loosen the screw and just be observant what you put apart. Then clean it.
Good luck.
Jun 25, 2011 | Lasko 2644 Tower Fan
How do u take apart x box 360 to clean
You shouldn't take it apart to clean, that would void the warranty. And with the high enough failure rate of the 360s, you want that free repair. I'd suggest blowing it out with an air compressor or something around those means.
Apr 18, 2010 | Microsoft Xbox 360 Console
Why is my playstation 3 not reading the disks
the laser could be bad or it might need cleaned.if you like takeing stuff apart then go for it if you dont like takeing apart stuff then dont do it. or instead of opening it and cleaning the eye.you could buy a cleaning cd with the brushes on the bottem.or you just could call sony if this doesnt help.if you would take it apart then look on youtube for a step by step video on how to take apart a ps3 so you dont mess anything up.hope this helps you.
Dec 12, 2009 | Sony Playstation 3 (PS3) Console
How do i pull apart my nokie E71 to clean the screen?
Here is a website with a pictured tutorial on how to disassemble your E71.
Be warned that doing so would void your warranty. So unless you don't have a warranty I wouldn't take the E71 apart to clean the screen.
How to Disassemble Nokia E71 Housing
Apr 15, 2009 | Nokia E71 Smartphone
Pinnacle Inertia Baitcast Reel Logo
65 people viewed this question
Top Pinnacle Fishing Experts
Tom Chichester
Steve P
Steve P
ray gallant
Are you a Pinnacle Fishing Expert? Answer questions, earn points and help others
