Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
Sealing in the cofee machine
The water are coming out from the steam tube side of the machine. but its seams like there is a problem in the brew unit. the water are coming out slowly then usual or not coming out at all. in addition we noticed that there is a strange sound every time the brew starts to draw out water for the coffee. we cleand with adescaling solution and still there is no change. dose the descaling solution gose thru both sides- the steam unit and the brew unit? is there any way to clean the water tubes that conectes to the brew unit? Thank you for every information.
  • pelican19 Oct 19, 2008
    Hey Mirran...you sound like you know your espresso machines...how do I access the steam valve? I have the same problem with my Rondo...thanks!
  • sofia73 Mar 09, 2009
    We hsd steam valve replaced with a metal one, it worked for another 3 cups of coffee and now same problem again...Can you help please?
    Thank you,
    Sofia
  • 515 Answers
You have to replace the steam valve, make sure you get one in metal.
Sometimes there will be a strange sound from the brewunit, make sure the filter in brew unit fits tight, if not you get a noisy sound from it.
Check also the hole in chassis behind the brew unit and make sure that is clean.
Posted on Jul 12, 2008
SOURCE:
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water leaking and coffee dry
Sounds like the boiler is blocked, and machine needs to be descaled. Try this first remove the parnello if your machine has one on the steam wand then using a paperclip clear out the end of the wand, that might be blocked. If it isn't then run the descale to clear out the blockage in the boiler.
Oct 05, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
No coffee coming out, just hot water
Two questions:
1- Is the coffee grounds wet or dry?
2- Does the spout drip water when the machine is just heating up?
If the grounds are dry then the brew chamber is not getting any water. Turn machine off, let it cool down, then remove brew unit. Behind the brew unit there is a white valve with 2 red o-rings(sometimes black), if you look closely there is a small lever between the o-rings, get a small screwdriver and gently lift lever and spring, if water came out then the problem is in the brew unit, unscrew the stainless steel screen which is under the large red O-ring on the brew unit and clean, also make sure the tube on the unit is clear.
If the hot water spout is not dripping when the machine is heating up then you're good.
May 12, 2009 | Coffee Makers & Espresso Machines
Low water pressure
i had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
Apr 09, 2009 | Saeco Vienna Deluxe
Magic
when you put the machine do you have water or steam coming out of the valve if yes the brew unit might be block check it out clean it or unblock it cheers
Jan 31, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
258 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
