SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
SOURCE: Drying problem
As I had the same problem, I worked on my machine and found out the heater unit was not working (it is a brand new machine ! - remark : as I moved overseas, LG did not cover it with their warranty).
But back to what I did : I ran the check program (instructions can be found in the Service Manual) and verified it was sending voltage to the heater on step 36. So I checked the heater unit (in the bottom of the machine) and found it was burned or open. So I ordered a new heater assembly ($40 on eBay), replaced it myself and am completely happy with the results.
Remarks : the heater is powerful enough to heat cold water to the temperatures required (I don't have hot water in the faucet); it seems that the heater also produces heat for the drying cycle (my dishes were completely wet at the end of the cycle before, now they get completely dry). My only disappointment, mentioned by some in the forum, is that the outlet during the drying cycle is in the bottom of the door, so steam condensates into droplets on the kitchen floor. But now I get clean dishes, and this machine is amazingly silent and efficient. Good luck to you !
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
SOURCE: 2 year old miele dishwasher runs without being turned on.
hi,
A F70 fault is the float switch in the base of the unit which is activated due to water in the base. you may have used too much detergent or the wrong detergent causing the unit to over sud or you have a genuine water leak. the continous running noise is the drain pump trying to remove any water.
you need to remove the bottom panel, turn the power off and dry up the water with a towel. then run it again and see if you can see a leak.
hope this helps
SOURCE: Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
