Question about KitchenAid KFP500 Ultra Power Food Processor
Kitchen aid food processor, the Juicer cone stuck on shaft and can not get it off
SOURCE: food processor, kitchen aid piece
Mine is stuck too.....I have not been particularly happy with this Kitchenaid product and this may be enough to send me back to Cuisinart.
Posted on Jun 08, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Kitchen Aid food processor, model # KFP 700 from 1970s
The closest I have seen recently - there is an auction for a complete KFP-700 with work bowl/lid intact on eBay right now:
http://cgi.ebay.com/Kitchen-Aid-12-Cup-Food-Processor-model-KFP-700_W0QQitemZ150328616612QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US
-Tha Mp3 Doctor
Posted on Mar 14, 2009
  • 145 Answers
SOURCE: I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
Posted on Jul 07, 2009
  • 145 Answers
SOURCE: I have a Kitchen Aid KPF700 Food Processor and
The unit has been retired, but Kitchenaid may still parts available. I would recommend to call Kitchenaid Customer Service and speak with their parts department. Their toll-free telephone number is:
1.800.541.6390.
Posted on Aug 08, 2009
  • 72 Answers
SOURCE: My 12 cup kitchen aid food processor dough blade
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Posted on Sep 17, 2009
Lid stuck on work bowl of kitchen aid processor
This tip is used to remove a stuck bowl from the base of a Kitchen Aid tilt-head mixer. It might work for your situation. Fill the bowl with very hot water (use the food shoot as a pour spout). Now use either frozen gel packs, or a bag of ice cubes, and lay the ice on top of the lid. Wait for a few minutes. The hot water with make bowl expand, ice will make lid shrink, thus loosening the tight lid. I'm assuming that the lid edge fits inside of the bowl, like most food processors do. Try to gently move the lid, and see if it'll give.
Mar 20, 2017 | Food Processors
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Aug 11, 2014 | KitchenAid Kitchen Aid 13-cup Food...
Kitchen aid food processors 's chopping blade gets stuck . Very hard to take it out
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
Aug 23, 2013 | Magimix 5100 Cuisine Systeme Food...
Slicer attachment is stuck
Take it in and get it fixed, a Kitchen Aid service person will have done plenty. Once you get it off that's not the end of it, there will be damage that will only cause it to happen again. New motor shaft sleeve and the piece that's stuck. Here in NZ they are not worth much so it's never an expensive job to do it properly.
Jun 24, 2013 | KitchenAid Food Processors
My 12 cup kitchen aid food processor dough blade is seriously stuck inside the bowl after I made some dough. How do I get it out?
Sep 17, 2009 | KitchenAid Food Processors
-Tha Mp3 Doctor
Mar 12, 2009 | KitchenAid Food Processors
Food processor, kitchen aid piece
Mar 04, 2008 | KitchenAid KFP500 Ultra Power Food...
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
KitchenAid KFP500 Ultra Power Food Processor Logo
198 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Don Eagan
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
