Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
I have just had this Robot595 for a week. I used it twice, and it worked well. It is plugged in at all times to the wall outlet, and the Battery pack/ base flashes green regularly.but the Robot itself does not work today when I tried it. Should it not be plugged in full time? I understood that that is what I am supposed to do with it. There is no life at all today, but as I said before it worked well when I used it last. I did not use it until it quit either time.. Help! Betg
pjszilard
  • 72 Answers
SOURCE: Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Posted on Nov 11, 2007
SOURCE: stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Posted on Dec 16, 2008
  • 61 Answers
SOURCE: light houses aren't turning on.
Make sure your virtual wall batteries are fresh-- even if you're sure they are, try removing and replacing them just to reset the virtual wall.
Then reset your Roomba: hold down "spot" and "dock/demo" for about fifteen seconds. Release them and wait for the tune.
Recharge the Roomba and then try to run it. The virtual walls ought to respond at that point. If they don't, you might find that calling customer support may help.
Posted on May 20, 2009
pappapumpdaf
  • 635 Answers
SOURCE: charging error 5 - battery not workiafter 4 calls and 4 different
Generic works fine, and that charger does too. If your charge light and dock light are on then you'll be okay.
Save cash, go generic!
Posted on Mar 11, 2010
kapishtech
  • 2272 Answers
SOURCE: My Roomba 560 does not charge - Rapid orange flash
Battery problem.If the battery is absolutely new,still it can be battery problem.But if the battery is old then replace the battery.To confirm the battery fault check the voltage of battery with meter.It should show exact volt.At least 12 volt.If the battery gets warm then the charging circuit is working but if not then the charging circuit is not working.failure is due to a failure with U2/U4 in the charging circuit. --------- For more troubleshooting,if you require service manual for your roomba model,please click on this link directly:--- http://choisirsonaspirateur.info/wp-content/uploads/2010/03/Roomba-500-Series-Service-Manual.pdf ------------
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Sep 29, 2010
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
Why is my eureka super broom not turning on?
When machine does not work, first check wall outlet ( plug in an hair dryer or table lamp to check wall outlet. ) and it that is OK than check your power cord for break ( if wire's are broken inside outer coating the cord will be very weak at that point )
May 15, 2014 | Eureka Super Broom 286 Vacuum
What does prong mean
A prong is usually a piece sticking out. Your vacuum has a power cord that plugs into the wall outlet. The metal pieces coming out of the plug that go into the wall outlet are called prongs.
Mar 12, 2014 | Vacuums
What would cause this to shut off after a few minutes of use with full battery charge
1) test the power cord for open, broken, loose or defective with VOM
2) test the outlet wall, for ground improperly, and repair.
3) Most of the time is THERMAL fuse, replace or fix it.
God bless you
Jul 27, 2012 | As Seen On TV Swivel Sweeper Vacuum
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
Its showing full battery then after 5minutes showing low battery...
You have a nearly-failed battery.
You'll need to replace your battery as soon as possible, or (like everyone does) use your laptop
while plugged into the wall outlet, because modern battery technology is so substandard, and
after 6 months of use, everyone's laptop battery goes marginal - just as yours has.
Sep 19, 2011 | Vacuums
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Oz
Feb 27, 2011 | Vacuums
Light houses aren't turning on.
Apr 06, 2009 | iRobot Roomba 550 Vacuum
Battery or ?
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
Jan 10, 2009 | Hoover H3030 FloorMate SpinScrub 500...
iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
