Question about Bachmann nyc 4-8-4 Niagara Steam Loco and Tender
I have a Bachmann Nyc 4-8-4 Niagara Steam Engine. I bought it brand New, And I've had it for a while. I just finished Custom painting it, and was running it aroundthe track, when it derailed. after setting it back up, It will not Run properly. At full Throttle, The Engine Slows To a crawl, and the tender Feels hot, with an electrical smell. Please Help!
  • 20 Answers
SOURCE: transmitter power lite is on but no power seen at engine-
There are two switches at the rear of the engine. One turns the sound on and off and the other turns the power to the engine on and off. Make sure you have the power switch turned on. It should default to full forward with the transmitter off.
Posted on Jan 04, 2009
SOURCE: Bachmann HO train set not working
I realized that you can't use two left hand turnouts because they end up making a short when the come full circle!
Posted on Jan 19, 2009
  • 135 Answers
SOURCE: bachmann overland locomotive has trouble staying on tracks
hit it with a bigger hammer!
Posted on Feb 19, 2009
  • 2976 Answers
SOURCE: I have a Bachmann electric train and the engine
An electric train is simply a DC motor and a gearbox. Take the body off and check the motor for continuity. If it checks okay, carefully, tourn the motor. You might have a broken gear in the gearbox. A good hobby shop should be able to find parts or, you can get them online.
Posted on Sep 05, 2009
SOURCE: I have an HO scale
Check the engine motor and second car motor with a digital multimeter for continuity. Make sure the track is connected properly. Also probe the transformer and see if it is sending out power to the track
Posted on Dec 20, 2010
Can you please give me the e mail address to contact Niagara as you suggest in your answer to my question as I can't find one but assume there is one as you recommended it. Thanks.
Hello Irene
You need to make this request in the original post under Tom's reply to you. You will see the word COMMENT, click on that and Tom will get a notification that you require further help. Fixya gets 9 million posts a year so the chances of someone seeing it as slim to none.
I am thinking one of these links will help you though.
Meynell Niagara (Niagara) shower spares and parts ' Meynell Niagara ...
https://www.showerspares.com/meynell_shower_spares/.../meynell_niagara_niagara/
  1. Cached
  2. Similar
Buy Meynell Niagara shower spares online. All shower spare parts for the Meynell Niagara in stock with same day despatch from the UK's #1 shower spares ...
Meynell Niagara 2 (Niagara 2) shower spares and parts ' Meynell ...
https://www.showerspares.com/...shower_spares/...all/meynell_niagara_2_niagara_2/
  1. Cached
... Niagara 2 shower spares online. All shower spare parts for the Meynell Niagara 2 in stock with same day despatch from the UK's #1 shower spares retailer.
Glass Inc,Niagara Falls,Glass,Showers Stalls,Shower Doors,Home
www.glassinc.ca/
  1. Cached
  2. Similar
Niagara Falls, Ontario, frameless shower enclosures, frameless shower doors, shower stalls, mirror, backsplashes, back painted glass, St. Catharines, Home.
Shower doors, bath screens - Niagara System Ltd.
www.niagara-wellness.com/productcategory/shower.../shower-doors-bath-screens/
  1. Cached
  2. Similar
Home/Shower enclosures/Shower doors, bath screens. Showing all 6 results. Default sorting, Sort by popularity, Sort by average rating, Sort by newness, Sort by ...
Here is the link to your post.
My Niagara bifold shower door fixtures are broken Is the Niagara company...
Oct 30, 2016 | Computers & Internet
Tip
How to use car rim paint?
1. Clean the hub with Latop Wheel Cleaner.
2. Cover the air ****, brake and the tire.
3. Shake the can before spraying, but avoid shaking during the spraying process. Keep 10-15 cm of distance.
4. Spray rubberized paint for the second time after 5 minutes. You are suggested to spray for 4-5 layers. Move the shade and you've finished it. Rubber Paint Spray Peelable Multi purpose Custom Rim Paint
on Jun 18, 2015 | Vehicle Parts & Accessories
What is the best way to lay down the clear coat over my finish coat on the fender I just painted but ruined when I shot the clear coat?
Refer to the paint manufacturer's data sheet to ensure the new gun has the right setup for clearcoat.
Could be the new gun was supplied setup for spraying a high solids primer or something that needs something like a 0.7 mm fluid tip. Clearcoat would need a 0.4 mm tip, an appropriate needle and a different air cap.
Data sheets are very valuable things. Don't forget to pick one up when you buy spray paint. A viscosity cup is another useful addition to the tool kit along with a graduated paint stirring stick.
Nov 24, 2015 | Air Tools & Compressors
How do you remove dried gloss paint from laminate floor
Try using a steam iron, put a damp cloth on top of the paint and then the iron on top and steam the paint, it may soften it enough to get it off with a plastic scraper so you don't mar the floor finish.
Sep 10, 2014 | Stanley Laminate Hardwood Flooring Staple...
Broken idler/reduction gear in ho power truck
Hi Jerry-
Split gears, unfortunately, often occur with plastic gears especially the older an engine gets it seems. They get brittle and crack.
I've provided a link to the Bachmann website-they offer a catalogue of parts and may have the replacement gear you require. You can also call them toll-free (the number is on the site) and provide the nice person with the model of your engine.
A little known fact is that Bachmann used to provide a lifetime guarantee on their locomotives. If the part you require is no longer made, they sometimes offer a replacement engine (new) at a substantial discount. You will have to mail in your old one. I used this service one time and received a brand new engine for about 60% off the cost of it new. A good deal!
My only other suggestion is to check in your area for local model train shows. You can search for them online. Most of the vendors are hobbyists themselves that sell model trains and supplies to make a few dollars on the weekend. Their trains are usually used but sell for a fraction of the price new. Sometimes you can purchase a beat up engine for its parts for a couple dollars, and sometimes they have parts that have been taken off used engines themselves. Bring your engine along with you and see what you can find. I find bringing an old engine back from the dead always very rewarding! Hope this helps! Happy modeling!
Bachmann Trains Online Home
Apr 01, 2014 | Bachmann Crafts & Hobbies
How to replace rubber wheel rings on a bachmann 0-6-0 ho scale steam engine
carefully remove the drive rod from the wheel, slip traction tire on the wheel and into groove in the wheel, replace drive rod. play with your train!
Feb 03, 2014 | Bachmann Ho Scale Trains Steam Engine...
Replace rubber tires
remove screw that attaches the side rod to the drive wheel, place traction tire in groove in drive wheel, replace side rod & screw.
Feb 03, 2014 | Bachmann Ho Usra 0 6 0 Steam Locomotive...
Bachmann big hauler casey jones steam engine complete large scalecomplete set in box want to sell.
Post it for sale on one of the online auction sites.
Check eee-bay for completed listings on Bachmann sets
to give you an idea of what people are paying for them.
Also compare prices of the individual pieces, to see
if it would be more profitable to break up the set.
Aug 11, 2011 | Bachmann Big Hauler Radio Controlled Train
Few questions from a new owner
and I absolutely love it (aside from the broken headlight!) but I was wondering what the deal was with the seeming variations of paint finishes on the Military bikes? Mine and many others that I see have the flat olive drab finish, while there are others that I see with a very glossy finish, and in some cases, pinstripes. What's the deal with the variances -- are the glossy finishes and pinstripes the result of custom modifications? Also -- huge problem while riding. I know she's a brand-new bike (only 25 miles) so there are probably some break-in kinks that need to be ridden out, but this bike dies on me all the time. Unless I'm CONSTANTLY giving the bike throttle, it'll just die. Whenever I go to stop at a stop sign and am in first gear, the moment that throttle is let go, the bike just dies. It seems like I have to constantly pull the throttle on the bike to keep her running, it just does NOT want to idle. Also been noticing some small problems in shifting -- never seems to shift as smooth as other bikes I've been on, and I'm not sure if this is because it's a brand-new bike, or just older technology -- I'm totally new to all of this so I'm really not sure. Any ideas?,The shifting gets smother within 1000 miles, I have 1300 miles and rarely have any false neutrals or as clunky shift problems any more. Like Scotty said give the throttle screw a turn to increase idle( should turn by hand located on the carburetor). I did have a loose carburetor to cylinder head(jug) rubber boot loosen on me and was leaking air making the idle rough on my bike .After I repositioned the boot back on and tighten the clamp at the carburetor I never had the problem return.,,,
Nov 10, 2008 | 2005 Enfield Military
Bachmann nyc 4-8-4 Niagara Steam Loco and Tender Logo
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
