Question about Dishwashers
Hotpoint bf1620 second and fourth light flashing
4 Suggested Answers
SOURCE: hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Posted on Sep 20, 2008
SOURCE: hotpoint dishwasher bf1620 - 1st
I have had this problem twice now and the problem is water in the drip tray. The guys at Hotpoint eventually told me what the light meant as he wanted me to have an engineer and the manual does not say.!!
So if your up to it uplug from the mains and turn water off to the unit, pull the dishwasher out and lay it on its side (first putting down towels as the water will spill out depending where it was in the cycle when it stopped).
At the bottom of the dishwasher along both long sides there are 6 screws ( 3 each side) remove these easy peezy. Gently remove the tray/plate as it has connections there. You will probably notice the water on the tray or in the gubbins (nice word). Get a dry towel and dry what you can not forgetting the tray itself. Then and this is the important bit, use a hairdryer on all the gubbins and the metal insides DONT FORGET TO DO THE TRAY ITSELF. Take at least 20 mins to do this getting everything completly dry.
Then put together again, stand it up gently and try it.
You may or may not notice the water in the drip tray or on the gubbins, it does not take much for it to stop working.
This has worked twice for me. Also with the help of the internet and costing me £5 I was able to remove broken glass from the drain pump. I have saved myself a fortune.
This is from a woman who knows NOTHING about this sort of thing so if I can fix it anyone can.
Power to the girls !!!!
Posted on Apr 25, 2009
SOURCE: HOTPOINT BF1620 1ST AND 2ND FLASHING LIGHTS
disconnect from mains take off water pump from under the washer and bench test (apply 240v to the contacts). If the pump turns and is OK refit it. |The next thing to do is replace the control panel behind the front door. the part you need is TIMER BIT100.1 'S5' ROHS + N1045048 and can cost from £37 - £90 try amazon. fit and fix. |The control panel provides 240v to the pump, hence why you should replace it because yours isn't possibly?. do continuity checks on the cabling.
Posted on Jun 12, 2010
Dishwasher Hotpoint bf1620
That is not a valid model number
Aug 08, 2014 | Hotpoint Dishwashers
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf1620 dishwasher flashing light fault
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
