Question about LG NB2020 Sound Bar
Sound Bar has static on surround setting - LG NB2020 Sound Bar
Whats a sound bar
A sound bar is an additional home theater sound device separate from your TV. It is generally designed to be set below, mounted below, or mounted above your TV and is specifically designed to enhance your home theater experience by providing you with clearer, louder, and more rich audio. Somw sound bars come with wired or wireless subwoofers. A sound bar is a less complicated alternative to a surround sound system.
Jul 21, 2014 | Sylvania Televison & Video
I can not get any sound from my yamaha sound bar
does the tv have optical out or coaxial out this is your only option for this sound bar.
Jan 18, 2014 | Yamaha YAS-101 Front Surround Sound Bar...
I bought this from a thrift store for $10 bucks. It works fine in normal mode but when I switch it to surround mode everything turns into static. No matter what input I select or what surround mode it's...
It sounds like you are activating a test mode to set your surround speaker levels.
Usually you should do this before using any surround sound modes.
If you could post the exact model; we can search for an owners manual.
Mar 24, 2011 | Sony Audio Players & Recorders
Trying to hook up this surround sound to a hdmi 1080p tv and cant get the speakers to make anything but background static. not sure if wires are connected correctly
You probably have to use the TV remote,go into the sound settings,and change it from stereo to whatever options there may be for surround.Good luck! Greg
Aug 22, 2010 | RCA -RP9972 190W Dolby Pro Logic System...
Brookstone wireless headphones have static along w/ tv sound
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Jul 12, 2010 | Brookstone Surround Sound Earbuds...
Harman Kardon AVR 500 Only works in NON-Surff mode ?
This is a good indication that the surround processing section has a problem. This can be anything from a supply voltage being missing to a defective processing IC. Without testing inside the unit, it wil be difficult to determine. With surround procesing turned off, the entire section is bypassed. This is why standard stereo mode sounds OK. The static sound is digital noise and can be poor processing or a bad D/A converter IC.
Hope this helps,
Dan
Feb 26, 2010 | Harman Kardon AVR 500 Receiver
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Sound is out when you turn tv on.
This model uses a single "Surround/Sound" circuit board. All of them go bad---probably why he was using a surround sound system for the audio.
Board part number is: X480242 and it is no longer available from Hitachi---the only way you can get it fixed is to remove the board in the set and have it sent out for rebuild--company is PTS electronics--they repair/rebuild all kinds of boards.
Considering the cost for repair/rebuild is almost 200 dollars it may be smarter just to do what the other person did--get an inexpensive surround sound and get the audio that way.
I worked on a lot of these sets with this problem--some brand new ones were bad this way--
With the back off of the set you will see on the far left wall (as you look from the back) the Surround board--it is not hard to remove (several plugs and a few screws).
This was in my view a design flaw--the board is full of surface mounted IC chips and several are mounted near the audio output IC---heat from the output chip over time causes all kinds of bad solder connections.
I saw one tech in a shop where I worked spend three hours trying to resolder one of these boards (special soldering for surface mounted parts etc) and the board still did not work right.
That board got sent out for rebuild and worked fine after. Lots of these have problems where when cold or hot sound problems come or go.
If this information has helped you, rate this solution as I do this here for free.
If you have questions or need advice let me know, I am here to help people.
SD TECH
Nov 05, 2009 | Hitachi 61SWX10B 61" Rear Projection...
LG NB2020 Sound Bar Logo
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
