Question about Hamat 3-3369PC Ergo Pull-Down Kitchen Faucet with Joystick Handle and Match...
Leaking sink - Hamat 3-3369PC Ergo Pull-Down Kitchen Faucet with Joystick Handle and Match...
Why is my kitchen sink leaking?
I think you should identify the problem at first)
1. A pressurized water hose leak
These will be really obvious - they'll be spraying pretty much constantly and creating a big mess.
2. A leak in the drain line
These will only become apparent when you turn your tap on and let the water drain away.
3. A faulty sink drain seal
If a leak doesn't appear in either case, try filling the sink with water, then let it drain away. This would suggest the issue is your drain seal.
A little bit of observation, trial and error should help you to work out which one of these issues is causing your leak.
In any situation you can buy a new sink - Best kitchen sinks
Jun 03, 2018 | Home
Seam of kitchen sink is leaking where the sinks where set into the frame of the sinks
The seam should have been sealed during installation.
Oct 11, 2016 | Home
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: FortĀ® Single-control...
The sink drain leaks
Sounds like plumbers putty un drain flange to sink may need to be replaced or strainer may need to be tighten up a little to see if that stops the leak.
May 05, 2010 | Plumbing
Installing above counter sink and is leaking on
They make a replcement over flow kit.
Mar 21, 2010 | Plumbing
My drain pipe has a leak
Tighten all connections first and see if you have a problem. If you still have the leak, then dry the piping under the sink (using a towel) from the sink downwards. Then fill the sink with water and then get under the sink and open the drain. Use a flashlight and feel for moisture with your hands. Start at the bottom of the leak and work your way upwards until you find the area where the leak is occurring. Often leaks appear to be at the bottom of the pipe but the leak can occur as high as the sink drain seal. Be sure to check the back of the piping for leaks. Once you find the leak, you can then determine the course of action to repair the leak.
Dec 29, 2009 | Home
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
Apr 18, 2009 | Eljer 212-1088-00 White Dumount Double...
WATER LEAKS UNDER THE SINK WHEN DISHWASHER IS IN
Check the connection to the drain tailpiece from the dishwasher under the sink and make sure the clamp hasn't slipped off and is tight. Check the drain hose from the dishwasher and be sure it's not split or damaged. Check the drain spur on the drain tailpiece and see if it's corroded or leaking. Check the trap under the sink as well and make sure it's not leaking.
Mar 27, 2009 | Jenn-Air Dishwashers
Hamat 3-3369PC Ergo Pull-Down Kitchen Faucet with Joystick Handle and Match... Logo
24 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
