Question about Sentry FIRE-SAFE Combination Safe DS3431, DS3431
Factory or default combination for model SFW123DEB
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Karbonn k222. How do I recover from a forgotten password?
This is going to take a factory reset on your device. power off remove your SD card then remove the battery if you can? some new devices don't have that option, now while "powering on" at the same time hold "volume down" (I think that is the toggle combination) if not that info is right at your finger tips, search your model & "reset recovery toggle combination" this will set your device back to factory default,, it might take several try's to get the reset menu to pop up, but it should take care of the problem, best wishes i hope it works for you!
Jun 01, 2015 | Cell Phones
6211-13-200adsl2a friend gave me this router, but they could not remember the password to use. How do I find it?
There is usually a way to reset the router to its factory defaults by using some combination of power off/on and holding a reset button. Sometimes the reset button is inside a small hole in the case where you have to insert something like a paperclip. Once you perform the factory reset, the router will have the default user and password. You should be able to find more specifics by Googling on the model number and looking through the User's Guide.
Oct 06, 2014 | Computers & Internet
Is there a default combination for brinks model 5054 safe
Contact brinks they may have a master code to unlock your safe...or try a good lock smith,they may have access to the code.
Jun 11, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
Reset bios
  • Restart the system. Click on "Start," "Turn off Computer" and "Restart."
  • At the Dell loading screen Tap "F2" to enter the BIOS. "Entering Setup" will appear. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  • Once loaded, depending on BIOS version and type, you can reset the defaults by using "F9" key to Load Defaults, the "Load defaults" button on screen, or the "Alt" + "F" key combination to load factory defaults.
  • Press "Esc" on your keyboard and select save and exit.
  • Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your system to restart for the BIOS settings to reset.
Aug 30, 2013 | Dell Inspiron Computers & Internet
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
I cant find out my router username and password, please help.
try these...
username: password: (blank means no password)
administrator administrator
operator operator
administrator
(less likely ones)
anonymous
user user
user public
PFCUser 240653C9467E45
If these all fail, reset your router and try again.
Mar 01, 2011 | Compaq (171979-001) Router
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
Dec 07, 2010 | Sentry Fireproof Safe
I am looking for my wep key, I got directed to the router site by typing in 192.168.1.1 like everyone on the internet suggests. When prompted to enter my Username and Password, I have used every...
Some routers have a RESET button that will reset the router back to the factory defaults. If you provide me with the make and model of your router, then I can give you the exact details on how to restore the router back to the factory defaults.
Nov 18, 2010 | Computers & Internet
Sentry FIRE-SAFE Combination Safe DS3431, DS3431 Logo
63 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
