Question about Sony KP-46WT510 46" Rear Projection HDTV
46" Rear Projection Issue
I turned on my TV this morning and the picture is curved (as well as any lettering detail on the program that is on). Any idea what the issue could be or how to fix?
  • jkube32 Dec 07, 2007
    Im having the same problem can you tell me where these parts that i need to check are located in the TV??? Please!!
  • LESBAK Dec 15, 2007
    OK HAD THE SAME PROBLEM REPLACED THE PART AND PROBLEM IS STILL THERE?
    Genius:
  • 1,694 Answers
Replace both convergence IC's STK392-560 mounted on large
heatsink ...+ check pico fuses 3.15 amp...............T.
Posted on Dec 04, 2007
  • Vista Electronics Dec 09, 2007
    jkube32,
    Main board with large, finned heat sinks....Stk's on the side away from you...............T.
SOURCE:
Top left of unit, there is a blue green stripe the covers five inches of the TV. When I hit the cable guide, the letters curve down to the right and look like they are in 3d. With a blue green and red...
Tv will get worse and will dies completely causes more damages to the other tv boards if continue using the tv this way.The tv have a problems known as a convergence problems,it dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 20, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Image curve
Image curve, it seems tv got problem with convergence output ICs failure.
Do you get off color picture or like 3 pictures in tv screen?
Is it Sony KP-57HW40 rear projection tv?
Let me know above info to provide you helpful info to solve this issue.
Thanks.
Jan 17, 2011 | Sony KP-57HW40 57" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
CircuitCity
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Problem with picture and sound
A board (signal) bad ? or possible B board.....proof is by
substituion = can get expensive.................T.
Oct 13, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
