Question about Brookstone Softtouch Acuvibe Body Massager
D3-15a 2 prong transformer and cord blew up and need a new one Where can I find this cord and transformer?
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Switched chords on dryer from four prong to three prong when plugged in the top left prong sparked did i fry my dryer or is this fixable?
This is probably fixable as you probably hooked the cord up wrong and it arced and likely blew the breaker before much was damaged. The 3 prong cord has obviously, 3 wires. As long as you get the middle wire in the the cord hooked to the middle terminal on the dryer, the other two wires can go to each of the outside terminals, no matter which one goes where. Correct the cord and you will probably be in good shape.
Sep 16, 2010 | Dryers
Swich 4 cord to 3 cord plug in
To switch from a 4 prong to a 3 prong. First remove 4 prong cord, save screws you will need them. Look a 3 prong, it will be flat with 3 wires next to each other with metal fittings on the ends. The 2 outside which are hot wires go to the outside screws on the block, and the center which is neutral goes in the center. The only difference in the cords is the 4 prong has a ground, in new construction this is code. You don't need a ground if house is wired for a 3 prong.
Jun 15, 2010 | Roper REX4634KQ Electric Dryer
Trying to change a 3 prong dryer outlet cord to 4 prong
you evidentally got a hot phase and a neutral mixed up on the terminal board which made the case of the unit hot 120volts,then it backfed through the case ground wire back to the neutral and this blew the fuse/breaker,if its a flat 3 wire cord, the 2 outside wires are your hot phase wires and go to L1 and L2 on the terminal block,polarity is not an issue soeither wire on either terminal,then the center one goes to the terminal marked N or neutral
Jan 20, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Need new electric cord(2 prongs) for coffee maker
I was pleased to find West Bend still around and carrying what one needs to avoid adding to the land fill:
2-Prong Cord
May 05, 2009 | West Bend (58036) 36-Cup Coffee Maker
Brookstone Softtouch Acuvibe Body Massager Logo
116 people viewed this question
Top Brookstone Health & Beauty Experts
Da Doc
David Ellis Rhea
Are you a Brookstone Health and Beauty Expert? Answer questions, earn points and help others
