Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
Oil gas ratio for troy built tb320 bu 31cc leaf blower
  • 77 Answers
SOURCE: I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Posted on Aug 11, 2009
  • 74 Answers
SOURCE: leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Posted on Aug 13, 2009
harlan301
  • 205 Answers
SOURCE: troy bilt electric leaf blower will not turn on
yes i would say your right, check your wiring to, make sure you have no shorts. good luck
Posted on Oct 17, 2009
  • 736 Answers
SOURCE: troy bilt tb320bv 31cc gas blower starts and runs
inside the fuel tank you will see a flexible fuel line with a filter attached to the end ... that filter acts as a weight to position the fuel line in the lowest part of the tank no matter what postion the blower is in ... make sure the fuel line isnt broken .. also make sure the filter is still attached .. you can replace the fuel line and filter but both have to be able to handle achohol (in the gas) .. most of the older fuel lines cant and they go bad in a short time .. its actually hard to find the correct fuel line ... the size is not usually a problem but the material its made of has to say its suitable for modern gas .. most i found at local shops are the old type and wont work ..
Posted on Nov 05, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: my troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
How to measure 2 stroke oil gas
Depending on the mix of oil to gas you can purchase a small bottle to add to the gas. I believe it is 8oz. to a gal. of gas. This should give you approx. 50:1 ratio. Hope this helps.
May 09, 2014 | Troy Bilt 31cc Quickshift Blowervac, Model...
What is oil-gasoline mix ratio
oil gas should be in ratio 1 to 50 or 2%
Jul 10, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
What is the oil type and oil/gas mix ratio needed for the Troy Bilt 31cc blower (TB310QS)?
I always suggest using a full synthetic 2 stroke oil for these machines. It provides superior lubrication qualities and burns cleaner than conventional oil. The fuel/oil mix ratio is 40:1. That is 3.2 ounces of oil mixed in 1 US gallon of gas. Half that to mix up a 1/2 gallon. You can find this info and more in your manual. The fuel info is located on page 10.
http://dl.owneriq.net/d/dcedfb0b-6611-4152-bbbf-d793d087365e.pdf
You will need Adobe Reader installed on your computer to view your manual as it is in PDF format. If you don't have it, you can get a free download from their site. It is safe.
Feb 27, 2011 | Troy Bilt 31cc Quickshift Blowervac, Model...
The bolts holding the fan to the housing came off and it won't start. Is it worth trying to repair or just trash it and buy a better built blower
Troy built is a very good machine but you might have answered your own question especially if the machine is very old.
Nov 18, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
What type and grade of oil is required. I have lost my manual and do not remember what oil is required. Troy model TB4SC gas blower.
Any 2 cycle oil will work. Then mix 1 gallon of gas to 1 container of 2 cycle engine, shake well and pour into your blower.
Aug 10, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
What is the gas mixture ratio for 31cc troy built blower
two stroke engines work best with a 40 to 1 ratio of gas to two stroke oil.
Oct 17, 2009 | Troy Garden
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
