Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Maytag MFI2269VEM3 Bottom Freezer how do you remove the upper bins
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: how to fix the water pressure on my maytag refrigerator mod# MFI2269VEM3
check for a water filter in the units water line system,also check for a plugged or defective water solenoid valve located in the lower rear area of the unit
Posted on Jul 24, 2012
MFI2269VEM3 does not detect temperature
Try resetting the control board by unplugging the refrigerator for a few minutes. Did you pull the thermistor or change it's location in the freezer section? Are those your photos on the link you provided HERE? So let me get this straight you began by cleaning the freezer section defrost condensate drain and ended up with the refrigerator freezer now unable to cool at all?Here is a link to a MFI2266AE Service Manual. I want you to go to page 37 and do the service diagnostic so we have a better idea of what has happened here I am here to answer your questions, Thanks Sea Breeze
Leaking Refrigerators
Jun 03, 2013 | Maytag Refrigerators
Ice freezing up on bottom of freezer and water MFI2269VEM3
Sounds like your drain in the freezer is clogged. Try a flexible item like a guitar string to clear it.
BUT also make sure that the fan is working and blowing the humidity from the freezer to the fresh food section.
Jan 04, 2012 | Maytag Refrigerators
Model MFI2269VEM3 ice maker not producing ice
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFI2269VEM3/3048/0161000/W1007012/00001?blt=06&prst=&shdMod=
First check if the compressor of the refrigerator run if not check the power supply.
Second check the piping of your refrigerator near of the compressor is hot or not.
Sep 05, 2011 | Refrigerators
Im thinking of buying the MFF225VE bottom freezer but am wondering can you remove the freezer baskets to clean the bottom floor of freezer?
The baskets do come out, there are some tabs that can be depressed on each side and the bins come up. If you want to take the entire drawer out you would need to remove a couple of screws from each side to accomplish this.
Let me know if this was helpful or if you have questions.
Thanks
Jun 14, 2010 | Maytag MFF2258VE Top Freezer Side by Side...
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
Maytag performa bottom freezer works but upper
First you should make sure your Evaperator fan is working. Open the freezer door and press the door switch in and see if you here the fan running.
If you dont here the fan you might have a fan motor problem.
Jan 07, 2010 | Refrigerators
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
46 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
