Question about Cuisinart DCG-20N Electric Blades Grinder
How do I open Cuisinart Coffee Grinder DCG 20 N
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
Posted on Sep 20, 2008
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
  • 3 Answers
SOURCE: cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Posted on Mar 13, 2010
SOURCE: My Cuisinart DCG-12BC coffee grinder,
.... mine stuck after "first" use ... solution ... took it back to the store, got a refund, bought a Mr. Coffee Model IDS77 which was $11. cheaper, has automatic grind settings and a superior bowl arrangement... Then I put Cuisinart on my list of DO NOT BUY ... anything can have problems, but something obviously this chronic should be handled better by the manufacturer ... it should have been taken off the market and fixed ...
Posted on Feb 17, 2012
ercupa190
  • 12223 Answers
SOURCE: I have Cuisinart Grind Central DCG-12BC.Yesterday it suddenly stopped working.
1) test the power cord for open or break with VOM
2) test the outlet box wall, put some another devices and see if working , if does the problem is the device
3) test the main switch for open or defective or loose wires, repair or replace
4) test for thermal fuse inside, for open and replace, see if your model hast c.breaker and reset it.
5) Try now.
6) Please read your owner manual, if you do not have download from www.retrevo.com and go the section troubleshooting
God bless you
Posted on Aug 01, 2012
My Cuisanart coffee grinder does not work (no power) after only a couple of months
you have to make sure the lid is securly in place for safety it will not power on if not correctly lined up and secure.
Oct 08, 2014 | Cuisinart DCG-12BC Grind Central Coffee...
DCG-20
There are two hidden screws on the botton in two small pilars. Use a drill in order to open the pilars and you will find out the philips screws.
Feb 21, 2014 | Cuisinart DCG-20N Electric Blades Grinder
I have Cuisinart Grind Central DCG-12BC.Yesterday it suddenly stopped working.I opened it,but I cannot find anything wrong in it.?
5) Try now.
God bless you
Aug 01, 2012 | Cuisinart Grind Central DCG-12BC Blades...
My Cuisinart DCG-12BC coffee grinder, the bowl is stuck on the motor base. It works and turns, but it will not come apart to be able to clean it. Please advise.
Aug 27, 2011 | Cuisinart DCG-12BC Electric Blades Grinder
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
My Cuisinart grinder was working one minute and stopped the next. Stopped working, will not do anything. Could the motor have gone out?
Before I would assume it is the motor, I would double check the switch that will not let it run if the cup is not pushed in all the way...
make sure there are no bits of coffe in the way keeping the cup out just a bit. it needs to be seated perfectly for the grinder to run...
If all that checks out then probably either the motor or the switch has gone bad....
If that is the case you might better throw out this one and nuy a new one... there are selling for 20-30 bucks new...not worth spending much time on to fix...
heatman101
Oct 07, 2010 | Cuisinart DCG-12BC Electric Blades Grinder
Need help using my coffee maker
Thank you for note I went on Cusinart site and found a copy of the manual and got my coffeemaker to work.
Dec 25, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Cuisinart DCG-20N Electric Blades Grinder Logo
165 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
