Question about Schumacher 400w Power Inverter
Schumacher xp2260 power adapter - Schumacher 400w Power Inverter
I have a schumacher xp2260 and am getting an error code of r02 but cannot find any information about it. Please tell me what it means and how to fix it.
I have no information on this fault. I suggest you contact the manufacturer directly with the question, but really doubt it will be something you can fix yourself.
Jan 09, 2017 | Office Equipment & Supplies
I have an error code of FOO ?
Joseph, No F00 maybe contact company. Digital Battery Charger Error Code Explanation Chart. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ERROR CODE DESCRIPTION REASON/ SOLUTION F01 The battery voltage is still under 10V (for a 12V battery) or 5V (for a 6V battery) after 2 hours of charging. Could be caused by trying to charge a 6V battery on a 12V setting or charger, or the battery could be bad, have it checked or replaced. F02 The charger cannot desulfate
the battery. The battery could not be desulfated, have it checked
or replaced. F03 The battery was unable to reach the "full charged" voltage. Could be caused by trying to charge a large battery or bank of batteries on too low of a current setting or the battery may have a shorted cell. Try again with a higher current setting or have the battery checked or replaced. F04 The connections to the battery
are reversed. The battery is connected backwards. Unplug the charger and reverse the connections to the battery. F05 The charger was unable to keep the battery fully charged in maintain mode. The battery won't hold a charge. Could be caused by a drain on the battery or the battery could be bad. Make sure there are no loads on the battery. If there are remove them.
If there are none, have the battery checked or replaced. F06 The charger detected that the battery may be getting too hot (thermal runaway). The charger automatically shuts the current off if it detects the battery may be getting too hot or the battery may have a shorted cell. Have the battery checked or replaced.
FAQS
Schumacher XP2260 Owner Manual
XP2260W Schumacher Portable Power 1200 Peak Amps
Mar 05, 2016 | Schumacher XP2260 6-in-1 Jump Starter
I can't recharge my Schumacher PSJ-1812 jump starter. I can't get an extension cord to plug into the outlet on the machine. I think it had a 12V power source adapter unit when I bought it bu
Not unless you can get the pc. back from the person lent it to or make him or her buy a new one or find the one that came with it !
PS. never lend your tools out
Oct 10, 2014 | PSJ-1812 DSR Jump Starter and Portable...
Where can I buy a replacement 45 amp fuse that goes in the Schumacher 750 watt power inverter?
According to the Schumacher 750W power inverter manual it can take two 40 or 50 amp spade type fuses which can be found on ebay with the link below.
40 amp spade type fuses
Sep 03, 2014 | Electronics - Others
How to replace hose (tire inflator)
I don't know that machine specifically, but you'd probably have to get inside the machine wherever the hose attaches to replace the whole hose.
Aug 05, 2014 | Schumacher Xp2260 1200a -engine Starter/...
I need to see how the wires go inside a Schumacher SE-1052 battery charger.
Most likely that is not the case. Battery chargers that are not really old have current sensing and dont switch on unless there is a load attached to it. A totally dead battery wont be seen by the device and it wont charge it.
Jun 12, 2013 | Schumacher SE-1052 2/10/50 Battery Charger...
Schumacher 400w Power Inverter Logo
47 people viewed this question
Top Schumacher Electronics - Others Experts
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
