Question about Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor
Compressor d110c21rax5 matsushita - Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor
I need the cooling capacity of a matsushita cnr05-980270 compressor. can anyone please assist?
I would need more information to properly answer your question.
What are you removing this compressor from?
The cooling capacity can vary greatly depending on the Evaporator size, the Condenser size and the fan speed that is moving the air. Also there are some other figures needed.
But if you could give me the application that you are using the compressor in I might be able to better answer your question!
Oct 11, 2013 | Matsushita DD73C14GAU6 1/4 HP R134...
I need the capacitor size for a Matsushita compressor model #2P19C3R126A Thanks
It just so happens that I am about to replace the compressor,on a marine A/C unit that uses the Matsushita 2p19c3r126a compressor. I believe it uses a 30 mfd capacitor.
Jun 10, 2011 | Heating & Cooling
I'd lke know, the HP of this compressor MATSUSHITA DB91C14RAW5 thanx
According to the information you have given it is a one quarter horsepower compressor
designed for R134 refrigerant. It runs on 115 volts.
Apr 03, 2011 | Matsushita DD73C14GAU6 1/4 HP R134...
Frigidaire r134a compressor.how can i know the horse power
It depends the model number, 452 BTU are 1/6 HP, R134a 776 BTU are 1/5 HP.
Dec 20, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
HP OF R134-ADMIRAL REF
it will be located on the compressor plate of the rateing of hourse power and amperage with the amount of freon needed to fill it.
Jun 25, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
Hi i am a refrigeration mechanic and i need a compressor for a chest freezer, here are all the reference numbers on the compressor, can you tell me the specs so i can get a match. SMH 2598133 Model no:...
i think any 1/3 hp 134a compressor will work you just have to make sure the fitting are in the right place,i got mine on ebay for $50 or you can check sears.com(parts) or repair clinic .com,let me know how you do-mike
Oct 28, 2008 | Refrigerators
Find compressor S51C90JAU6
are you needing to find the compressor on your fridge or a replacement?
Aug 15, 2008 | Refrigerators
Matsushita DD73C14GAU6 1/4 HP R134 Compressor 115V/6Compressor Logo
448 people viewed this question
Top Matsushita Heating & Cooling Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Marat Brikov
Are you a Matsushita Heating and Cooling Expert? Answer questions, earn points and help others
