Question about Power Acoustik Car Audio & Video
Power acocstixptid 8920b, how do i wire the orange wire, call ed dash light elimination wire . What do i hook it too?
  • bill young
    bill young Oct 20, 2013
    the acoustik stereo ptid 8920b the reverse pink wire were to hook it to what wire
5 Suggested Answers
justuscc
  • 360 Answers
SOURCE: after market radio wires causes light issue with light switch
check your ground on the radio......... the feed from the lights will test as a ground and the radio will use this as a circuit and turn on the lights. been there done that what a nightmare
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: car radio
That wire is an unused spare
Posted on Jun 08, 2009
  • 8 Answers
SOURCE: I am trying to install a van radio. When I hook
If it"s an aftermarket radio, orange wires often aren't used, (it's usually for dimming) try it without connecting the orange wire, but be sure not to leave the wire exposed.
Posted on Apr 25, 2010
jturcotte
  • 8274 Answers
SOURCE: i have a 1998 saturn
Hi, not sure what model you have, but you can get the factory wire colors here: http://www.modifiedlife.com/request-a-saturn-car-radio-stereo-wiring-diagram/
page down to select your model.
It sounds like you tapped into the brake light wire rather than the illumination wire. Also, there should be an antenna wire in the car if you have a retractable antenna. Did you purchase a GM connector with the new steroe to wire it in?
Posted on Mar 12, 2011
I need a 12 volt switched power supply for my sirius radio, where cani find a wire i can hook into?
Check the large wires coming down the steering column from the ignition switch. Use a test light and find one that illuminates the test light with the key in the on position.
Feb 15, 2016 | 2005 Pontiac Bonneville SE
1999 Honda Accord No Dash Lights
U f---ed up. How come you have those two wires not attached to anything? Never like that in first place, was it?
Go over all you did or better still have some one with smarts go over your work and , hopefully, they will find what you did wrong.
Apr 15, 2017 | 1999 Honda Accord
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
Why are there 4 orange wires in the radio wire harness 2000 satern am/fm/cas/cd. What are they for? I understand the orange is the 12v+ do I hook up all 4?
Get a test lamp one should be hot all the time One should be hot when you turn on the key to run position One should have power when dash lights are turned on The last should be ground Good Luck
Dec 05, 2010 | 2000 Saturn Ls 4dr Sedan
Apr 22, 2010 | 2001 Chrysler Voyager
How do i hook up dimmer wire
If by dimmer wire, you mean the orange wire (also known as ''illumination''), 99% of the time, you don't. Otherwise, your brake lights or dash lights etc. could end up staying on. I believe that it's meant more for older older cars, but it's not necessary to hook it up. If that isn't what you meant, I apologize, if it is, I hope it helps!
Mar 03, 2010 | Car Audio & Video
Diagram wires on pionner.... some body know what is the wire orange with white on the pionner DEH-P4900ib??
In car audio wiring the orange/white wire is for illumination, connect it to your lighting switch it is to auto dim the display lights when you turn on your dash lights at night otherwise the pioneer display lights can be annoyingly bright at night. You don't have to hook it up if you don't want to, but don't forget to terminte the end of the orange/white wire with a crimp cap or black electric tape wrapped around the end well, I would recommend a crimp cap or similar. Good luck !
Nov 26, 2009 | Televison & Video
After market radio wires causes light issue with light switch
Oct 02, 2008 | 1996 Dodge Dakota
Head lights make the radio come on and , i have to unhook the cd player from the harness to cut off the parkinking and tail lights
on the back of the stereo (assuming it is an aftermarket unit) there are only 4 wires that deal with power.
Black- Ground
red- 12V+ turns on with the key
yellow- 12V+ always on
orange- illumination circuit,
the orange wire is most likely hooked up, it is intended to change the brightness of the radio when you turn on the headlights, however it always causes problems, best bet is to disconnect the orange wire, you do not need it, i am 99% sure it will not change the function on the lights on the deck.
dash lighting in cars runs on reverse polarity so a dimmer circuit can be used on a DC power system. the radio does not understand this and it causes strange issues like this one, give it a shot, please let us know how it goes.
thanks
JCC
Apr 26, 2008 | Car Audio & Video
Car radio
Jan 07, 2008 | Jensen CD4610 CD Player
Car Audio & Video Logo
24 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
