I realize that the subject problems are all common but has anyone had a combination of all the above? The problems I am experiencing with my console is are as follows:
1. A couple of days, I was playing Stranglehold and in the loading screen, the game froze. I restarted the console and got the 3 red lights. I shut the power and restarted the console and it worked perfectly. I let out a sigh of relief and continued playing.
2. Next day I hook it up again. I turn on the power button on the console.....and I wait..and I wait...and I wait...and for a good 30-40 seconds, the only light on was the middle power button. After that time, the console started and worked perfectly. Later the same day..I turn it on again..and again after the same 30-50 second delay..the red lights appear.
3. Now basically, what is happening is that once I turn on the console..it takes a good minute for something to happen. It can either be the red lights (3 reds) or the system works perfectly or...the green lights circulate..a couple of times and die out leaving only the middle green light on.
Any idea what is happening? If this was a hardware failure, the system would not start on a few occasion. All suggestions would be most appreciated.
Comments:
Sep 27, 2007
- Cerfer39 my friend,
Thank you for your response. I complete agree with you that it appears that heat is the problem. As I mentioned in my problem, the console does start sometimes but it then hangs after playing for a bit. I checked the console and it was steaming even though it is out of sunlight, on a table, no carpet and completely ventilated.
The industry is trying real hard to come up with a solution. Microsoft has extended the wrranty for people like you. Problem is that I hear they just send you a refurbished unit that will do the same thing eventually. Best plan i have heard is to do things to keep the Xbox as cool as possible. Currently I am not sure what to do with the Slow boot up. Keep it in open air area and out of sunlight. It helps to allow a fan to blow on it during play.
Comments:
Sep 27, 2007
- hi Kashman,
me again, another tip is to not let it set on Carpet. Position the Xbox to allow air to flow all around the unit, underneath included. The main problem is heat.
I need a replacement FS USB Header for the xbox 360 and you said that you know where you can get...
(More)
I need a replacement FS USB Header for the xbox 360 and you said that you know where you can get them for $10. I have looked everywhere for the part number and all I can come up with is the board location (J9G1). If you can I would appreciate it.
Some of my friends I can not connect to them in a party and they can not connect to me. But other...
(More)
Some of my friends I can not connect to them in a party and they can not connect to me. But other friends I have we have no problems. My friend that I have problems with can connect to them just fine as well??
