Question about SimpleTech ProDrive (PRO1000Q) 1 TB FireWire 400 (1394a) Hard Drive
What is the proper dc adapter needed and dc port mm?
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
My Thinkpad A30 replacement battery is not charging and is not even being read by my battery miser program. Does anyone know why?
Welcome to FixYa!
Im very sorry to hear that, it may also be the AC adapter that you are using. Worst is the DC port, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
May 17, 2011 | IBM ThinkPad A30 2652 Notebook
Battery light is blinking red and will not charge
Welcome to Fixya! If the battery light is blinking red,that indicates low power, there's a possibility that the problem is with the AC adapter, or the battery or maybe the DC port itself, please follow these simple steps for you to be able to isolate the exact problem.
Feb 28, 2011 | Panasonic Toughbook CF-73 Notebook
Battery is not charging
Hi, You maybe encountering errors such as plug in not charging or no battery detected. If so, there's a posibility that the problem is with the battery itself or the charger that you are using or worse, the DC port on the laptop. Here some steps for you to be able isolate the exact problem and which part is need to be replaced.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard or the Base Cover of the laptop itself.
Feb 18, 2011 | Gateway MD7818u Notebook
I am not able to open my laptop lenovo G460
Hi kabi_a11,
If you're unable to turn on your laptop there's a big chance that you're having power issue. Consider checking your Battery, AC adapter and DC In port.
1. Basic troubleshooting for battery is by reseating it. Kindly make sure to put it back properly.
2. For the AC Adapter, check the light indicator for it. If it's not defective you'll see the blue light on the brick. You may also try using other AC adapter with same power supply. And if other AC adapter works with your PC then it's the AC adapter that goes with your PC needs to be replaced.
3. One of the possible cause for your computer not to turn on is because the DC In port for the machine is loosed. No power will flow from your AC adapter to your PC.
If after checking and still computer won't turn on I will now recommend you to contact the manufacturer. Lenovo offers repair if machine is under warranty.
Hope this helps.
Feb 16, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
My Dell D610 will not run on the power adapter nor will the adapter charge the battery. I tested the power brick and the battery on another D610 and they are good. If I charge the battery on another...
the port that you plug the power adapter into is probably bad. common problem with laptops/notebooks. if you do a Google search on the subject you will find many companies that will repair this port. you may have a computer shop in your area that can do it.
Jan 30, 2011 | Dell Latitude D610 Notebook
Need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
Jan 16, 2009 | HP Photosmart Photo Film Scanner (35 mm)
GP4101 Powere Supplay
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Sep 03, 2008 | Gyration Ultra Cordless Optical Mouse
Adapter plug size
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
Aug 28, 2007 | RCA DRC620N Portable DVD Player
Open Questions:
See all SimpleTech ProDrive (PRO1000Q) 1 TB FireWire 400 Questions
SimpleTech ProDrive (PRO1000Q) 1 TB FireWire 400 (1394a) Hard Drive Logo
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
