Question about Wingscapes 8.0 MP BirdCam Digital Camera WSCA03
Cant read led bar - Wingscapes 8.0 MP BirdCam Digital Camera WSCA03
I think you mean LCD display? If so, then LCD displays with missing columns or lines can often be improved by gently heating the ribbon cable where it connects to the circuit board (using a hair dryer, for example) and gently rubbing the connection area with a pencil eraser. Haven't tried this on my wingscapes cam (because I can sort of still read it) but when it gets too messed up to use I'll give this old, tried and true method a shot.
Posted on Jul 12, 2014
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
Nov 10, 2012 | Frigidaire Affinity ATF8000FS
E68 error code
This E68 is a stuck keypad.
The error E68 means the CCU has sensed a stuck button on the console. MANY times this is a false error and means that either the CCU or interface must be replaced, but SOMETIMES, there really is a stuck button. Try to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1 time and " res" will be shown briefly in the display.
come on.
Key test:
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the interface OR CCU, but in my experience, it's usually the interface that ends up needing replacement. Here is a link to the interface board.
Oct 15, 2012 | Frigidaire Affinity ATF7000ES Front Load...
I'm trying to play call of duty but when i point at the sensor bar my pointer keep going to the right .
go to your console options and calibrate the sensor bar. increase the output.
the sensor bar is nothing more than IR emmitting LED lights that the remote reads. Too much sun or other IR sources will cause issues.
Mar 21, 2011 | Nintendo Wii Console
The hand will not show on the screen Have tried the 2 suggestions advised
usually there are two reasons for this
-1- the wiimote has not been synced, if the blue leds keep blinking you need to sync if one of them lights continuously that's not the issue.
-2- the led bar can not be seen by the wiimote due to the following reasons.
- obstructions between the led bar and wiimote
- the led bar connector is not plugged in the wii
- the led bar is defective
Dec 26, 2010 | Nintendo Wii Console
CANT GET SOUND FROM SOUND BAR VSB200 INT VIZIO VP422. THE LED LITES COME ON, THEN ONLY TWO STAY ON, THE INPUT SWITCH DOESNT DO ANYTHING, EVEN HOOKED UP AN OPTICAL CABLE.
I had a similar problem. I tried all the TV settings, but still it would not work. I plugged the sound bar directly into the cable box (AT
Oct 15, 2010 | Vizio VSB210WS Soundbar
DSG 140 LED display faded, cant read the display
LCD fades can be caused by many issues HOWEVER none of them are user serviceable. Contact the customer support team for a RMA request!
Sep 28, 2009 | Sport & Outdoor - Others
Gsxr 1000 k1 system dead
you imobilzer may not be reading you key check for overide sequence and try with imobilizer disarmed
hope this helps
Aug 09, 2009 | 2001 Suzuki GSX-R 1000
Handle over the big wheels
To move the handle bar (either for folding or to change into the off-road mode) push the small white button in (located on the inside of the handle bar) and pull both triggers toward you (also located on the inside of the handle bar - on either side) This will enable the handle bar to move.
I hope this helps.
Feb 24, 2009 | Bugaboo Gecko - Green Standard Stroller
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Wingscapes 8.0 MP BirdCam Digital Camera WSCA03 Logo
54 people viewed this question
Top Wingscapes Cameras Experts
Are you a Wingscapes Camera Expert? Answer questions, earn points and help others
