Question about Samson Technology Zoom R24 Multi-Track Recorder Controller
Project button wont work on my Zoom R24, I press it and nothing happens
3 Suggested Answers
  • 367 Answers
SOURCE: I HAVE A ZOOM R24
So I assume when you say you downloaded the latest drivers, you are talking about the version 1.3.0 from this source: http://www.zoom.co.jp/downloads/r24/
Ok so to configure Apple Logic Pro to use this control surface follow these instructions:
CONTROL SURFACE SETUP
1. Select "Preferences" > "Control surfaces" > "Setup..." from the "Logic Pro" menu. This opens the "Setup" window.
2. Click on the top left "New" and select "Install" from the pull-down menu.
3. Select "Mackie Designs/Mackie Control/Logic Control" from the list in the "Install" window and click the "Add" button.
"Mackie Control" will be added to the setup window.
4. Click the "Mackie Control" icon. Then, from the top of the list at the left set "Out Port" and "Input" to "ZOOM R16_R24" using their pull down menus.
FUNCTION KEY SETUP
1. Select "Preferences" > "Control surface" > "Controller Assignments..." from the "Logic Pro" menu. This opens the "Controller Assignments" window.
2. From the "Zone" column select "Control Surface: Mackie Control." Change the functions as you like.
3. Controls F1~F5 correspond to the F1~F5 keys on the R24.
The above procedures are for Logic Pro 9. The names of the menus, for example, might be different in a different version of Logic.
Make sure you have run all the MAC OSX updates from your System Menu > Check for updates.
This device needs full USB power so don't run it off a USB hub unless its a powered one.
Posted on Sep 09, 2011
  • 5380 Answers
SOURCE: SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Posted on Jun 01, 2012
Testimonial: "Thanks Cindy, now I just have to work out why it wont turn off, even when I go into 'tool' -->Metronome-->Off, it is still heard clicking on the track I'm recording and the tempo light still flashes. Bye for now, Lea"
88 shows up when i turn projectmix on
It sounds like an adapter issue. The PMI/O say's to use a 9v adapter, but the manual on page 9 says 12v. Try 12v if you use 9v or vice versa.
Powering on while holding the Zoom button will enter a test mode.
To do a reset. Setup>Factory Defaults>SEL>Yes
Nov 26, 2015 | M-Audio ProjectMix I/O
Circuit diagram zoom
are you kidding...so if you replace it and it burns up again what are you going to do?
Jul 21, 2014 | Peavey 32fx USB 32 Channel Mixer
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Have new min-etune gibson studio. charged battery, put in, nothing happens. no lights no nothing? Now What
Press down on the battery, which will allow it to pop up, as if you were going to remove it. Press the power "on" button. More than likely, your Min-Etune will now work fine.
Oct 28, 2013 | Gibson Robot SG Special LTD Ebony
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
H1 wont power on
I just discovered the same problem with my H1. When plugged to computer, nothing happens neither. It turns out it may be just the contact issue. You will have to carefully disassemble it (you'll need one small screw driver. watch for the small wires). There are two PCB boards one on top of the other, and between them there is the contact that I believe came loose or dirty causing the issue. Play with that, and with battery in, try to turn it on.
Apr 03, 2012 | Samson Technology Zoom H1 Handy Recorder
Will i need to buy a midi controller to record with my zoom r24
no, but if you want to control anything remotely you would need one
Mar 19, 2011 | Samson Technology Zoom R24 24Track...
Hi my zoom g1x fx is having some sound issues,it creates unpleasant noises and the sound kinda fades. I noticed the fading of the sound when i'm picking the thinner strings but it sounds so loud on the...
Hello. I am assuming that you are using the manufacturer supplied mains power supply and not running it from battery (otherwise replace the battery before doing anything else). I have noticed a similar problem occasionally with my Zoom G1XN too - mostly when I have been using it with headphones plugged directly into the pedal. Sometimes gently wiggling the output jack plug seems to have solved the problem - however I have had it occur when using the pedal with an amp too. Next step would be to try using different jack leads (or swapping the ends round) to make sure it is not a problem with poor contacts in the sockets. If this seems to solve the problem a little squirt of switch cleaner in the sockets wouldn't go amiss - but leave it 24 hours to dry out before using again. Do you find it only happens on some patches or on all of them? I have one patch that is absolutely clean (straight through with every effect set at flat/zero). Try that with one patch and see if it still does it and to give you a quick comparison. However, I think there may also be a bit of a problem with the effects processor itself (either in the design or the circuitry) - let's face it the GX1 is a modestly priced unit and they probably keep the price down by using cheap components. My usual solution has been to switch it off and remove all the plugs and start again. This has worked but is kind of annoying if it happens in the middle of a gig or half way through recording a song. Lastly I would try re-calibrating the expression pedal. as follows
  1. Turn the unit off
  2. Hold down the PEDAL ASSIGN button whilst turning on the power/ inserting input jack-plug.
  3. Raise the expression fully and press the STORE key (display should read "UP")
  4. Push the pedal down as far as it will go, until it hits the stop, and then release it (it will return slightly at this point)
  5. Press the STORE button again.
  6. If the display reads "Er" repeat the process from step 3 above.
Jan 30, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
Sep 16, 2010 | Zoom H4 Handy Recorder
Samson Technology Zoom R24 Multi-Track Recorder Controller Logo
15 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
DROPNDEAL
DROPNDEAL
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
