Question about Epson Stylus C44UX InkJet Printer
Epson cx44ux Both red and green bottons are constantly flashing on my printer. I get an getting no response at all, i have tried to put the print head into refill position etc. I have also run the ssc utility but no response. Please advise Regards John
  • jb11 Jan 08, 2008
    both red and green light's are flashing and it say,s need,s service
  • Anonymous Feb 27, 2008
    Have the same problem
I am on day 5 waiting for this crack professional tech support team from Epson to spring into action. I am having the same problems. First, they tried to say I was using Linux and they don't support Linux. OK, Fine...I hooked it up to an XP machine and it is still alternately flashing red and green lights. I keep the maintenance button pushed all day and it doesn't bring the cartridges into line so I can change them. This all started after changing cartridges and printing a test page. Test page was beautiful but that's when the lights started blinking and I haven't had a printer for days.
I do have the solution though, but I doubt Epson will allow it to be posted. I went to best buy and purchased 6 hp all-in-one's for our offices. We have always used Epsons but when they ignore their customers like this, I cannot afford to wait out their arrogance.
I might suggest the HP printers have been supurb and my tech support questions have been answered inside an hour.
Ken Starks
Austin Texas
Posted on Mar 24, 2008
SOURCE:
Printer was working fine and now it registers that there is a print in the queue and tries to start print cycle but then flashing red light comes on at the start of printing along with constant green...
Check the status monitor and see what further error message ... for this model, it's very prone to mech problem at the feeding area, you will need some tech know how to remove and repair.
Jan 20, 2011 | Epson AcuLaser C900 Printer
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
Apr 07, 2009 | Epson Stylus C60 InkJet Printer
Epson C66 problem
Without the benefit of a response from any of rickyostrom, liusgarciaca, or hotdog233311, I think we can say the problem lies with the fact that your magenta cartridge isn't printing. You can confirm this by carrying out a nozzle check print.
If any of you would like further assistance in restoring your magenta to working condition, please do a new post to this effect.
Oct 29, 2008 | Epson Stylus C66 InkJet Photo Printer
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus C44UX InkJet Printer Logo
182 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
