I have a toshiba pa3705d-1et1 wireless keyboard 7 i was working fine but has disappeared from my devices . the batteries are new
TOSHIBA wireless multimedia keyboard model PA3705D will not connect! Blue light on dongle does show. Help.
Be sure to install the latest drivers and also if you are using windows,
uninstall the device and reinstall it.
Aug 21, 2013 | Computers & Internet
Wireless mouse pa3706e-1et1 no longer operates my computer even though new battery installed and software re-installed.
Aside from the fact that the mouse may have gone bad, have you tried pushing the "connect" button on the bottom of the mouse? Also, is the battery in correctly?
Change the USB port to see if that helps.
May 19, 2011 | Toshiba Wireless Mouse PA3205U-1ETC
The keyboard is not working. Nothing comes out
I don't know your level of technical experience, so some of these may seem obvious. These may not be in the best order, I've added them as I thought of them.
1) check the batteries in the keyboard and mouse. They can go through batteries in a big hurry sometimes. If just changed double check polarity.
2) check the connection(s) for the receiver. If you have pets check for chewed wires.
3) have you added any new USB devices. They may be using to much power from your USB ports
4) have you added any other wireless devices, includes non-computer devices.
5) have you tried resetting the keyboard and receiver signal.
6) check USB power output. You can plug in a different USB device and see if it works.
7) does your receiver require batteries (very rare).
8) you may need to reinstall your keyboard drivers and software.
Most wireless keyboards operate in the 400 Mhz range so do most wireless networks and many phones, these can all interfer with your signal.
Jun 30, 2010 | Microsoft Wireless Optical Desktop 1000...
Hi there, I've got a Toshiba mouse, model number
Maybe mouse needs new batteries.
Take that "Small(wireless) part and put try it in another usb port
Aug 25, 2017 | Toshiba C99704 Mouse
Hi there, I've got a Toshiba mouse, model number PA3706-1ET1. It's a wireless mouse and each time when I turn on the computer the mouse stops working. So, after a couple of times removing that small...
first check the batteries inside the mouse they might be low, if that didn't work then try that muse on a different pc to make sure whether it is form the wireless mouse or from your workstation (windows problem or driver corruption).
Apr 18, 2010 | Toshiba C99704 Mouse
Touchpad on Toshiba WIreless Keyboard PA3705D does not work. Help
I have the Toshiba PA3705D-1ET1 keyboard.
I experienced the same thing: keyboard working, but not the touchpad. I reinstalled all drivers that I could think off, but nothing helped. What actually did work for me was: remove the batteries of the keyboard for 10 seconds, then put them back in (while PC is turned on). Also ensure that the batteries are full and that you are in range of your PC (let's say less than 4 meters).
Jan 10, 2010 | Computers & Internet
Wireless keyboard wont do anything
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Dec 15, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard not working
To connect the keyboard or mouse to the computer, you must connect the wireless device through the USB port and get it to hold a good connection. You do not have to install any devices to use these products, they automatically work when you plug them in. When it says that the device is recognized, you are ready to use it! If you have a desktop, you can also plug the wireless device to the mouse port. The keyboard and mouse work properly up to 5' away from the connected wireless device. If you can get the wireless device to work properly, you should have no troubles with the product.
Dec 29, 2008 | Innovations kb985w RF Wireless Keyboard
Keyboard problem
If its a wireless keyboard, replace the batteries. If its not wireless, try plugging it into another port(if possible) and if it still doesn't work, you probably have a defective keyboard.
May 29, 2008 | Toshiba Satellite P105-S9722 Notebook
Computers & Internet Logo
David Payne
David Payne
