Question about Prada SPR06I Sunglasses
Replacement lenses - Prada SPR06I Sunglasses
Cant find holbrooke oakley lenses replacement... if there any way replacement lenses for tham&
Typically Oakley has replacement lenses for their glasses but because the Holbrooke is so new it is probably going to be awhile before they have parts available. The guys at www.sunglassreplacementlenses.com could probably custom make you a set of after market lenses for about half of what Oakley will want for their lenses. You may want to email them if your lenses are thrashed.
Thanks
Jun 03, 2011 | Oakley Holbrook Sunglasses
Broken lense to police sunglasses. These glasses are approx. 12-15 years old but are much loved. Mod Police 2346 Col 647
As there is obviously no warranty any more, the only way is to see a good optician, best one who is selling police, and have both glasses replaced. It's impossible to replace only one because the optical lenses are now technically much more advanced as well as the colors. Whether it's worth the time and the expenditure for these old glasses you will have to decide after getting an estimate of cost for the new lenses and repIR
Apr 30, 2011 | Police Clothing Accessories
Can't find replacement lenses for Oakley Holbrook polished black/gray polorized
You can order replacement lenses from Oakley on the link below.
http://www.oakley.com/search?Ntt=Replacement+Lenses
If you do not see the lenses on the link contact oakley at this link below to order them.
http://www.oakley.com/customer-care/customer-care-info
Mar 13, 2011 | Oakley Holbrook Sunglasses
Need to replace grille lamps
When you look at the glass lamp covers (lenses), you will see a little raised section either at the front or back of the lense, depending how the lense was replaced previously. You need to put the largest screwdriver blade you can under the lip and turn it slightly. The cover should move and then ease the screwdriver round the lense until the lense comes clear.
Note. Cooking gunge may may this action difficult as it will cause the lense to stick and also when you replace the lense, you will see on the inside of it there is a moulding cut away to clear the bulb. Make sure when the lense is replaced, the recess is positioned so that it clears the bulb. Whilst you have the lenses out, use the Lakeland brush on oven cleaner to give them a good clean. The end result makes a difference!
Sep 30, 2009 | Stoves 720EF Electric Double Oven
Prada SPR06I Sunglasses Logo
32 people viewed this question
Top Prada Clothing Accessories Experts
Da Doc
ray gallant
Are you a Prada Clothing Accessory Expert? Answer questions, earn points and help others
