Question about Northstar 6000I GPS Receiver
Northstar 6000i beeping - Northstar 6000I GPS Receiver
3 Suggested Answers
  • 43 Answers
SOURCE: yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Posted on Oct 15, 2009
  • 503 Answers
SOURCE: leak inside gps
Leak inside a gps is usually just a battery, sometimes they overcharge for to long and when happens the battery deforms and leaks. I have no idea where to send them to for repairs, bbut usually they are not that complicated to get into them and remove and replace the battery, they batteries in most gps units are the same size and usually the same shape as cellphone batteries, they just have different connections on the outside of them, but the insides are usually the same, also you might have one that you can run without the battery in it. I would suggest that you might want to open (if no warranty on it) up carefully, remove the battery and see if you can run it that way. Be advised though that if you do this, any power interruption to the unit while you are driving will cause it to shut down and you will have to start your trip entry all over again. Hope this helps.
Posted on Apr 26, 2010
How do I get some keypad buttons working on my 6000i Northstar chart plotter?
good luck with that most companys wont repair there systems they update you to a newer one for about 500 dollars more
Mar 29, 2013 | Northstar 6000i 12" Color Display With...
Enter button does not work
bad key pad common on that unit sorry
I have a Northstar 6000i that will not display the tide track information. It has for 3 years,and now has a message stating that it can't display the information for the current date.
Probably the data didn't go past 2010. I have a Northstar 951XD, and first time out this year, no more tide track data - my manual says it only went fron 1994 - 2010. So how to get updates?
May 15, 2011 | Northstar 6000I GPS Receiver
How do I get a manual for a 6000I?
Retrevo has the manual to the NorthStar 6000i here: http://www.retrevo.com/support/NorthStar-6000i-GPS-manual/id/534ag415/t/2/ . You will need to enter a code to download the PDF. This is the Quick Start Guide and the Reference Manual.
I hope this helps.
Apr 30, 2011 | Northstar 6000I GPS Receiver
My 6000i gps willnot load charts
Greg,
Let me know if want to sell your Northstar for parts. I have a dead unit and need a main board. All else works fine but the repair at the catory is $799.00 which makes no sense.
bobanderson_2000@yahoo.com
Dec 06, 2010 | Northstar 6000I GPS Receiver
Leak inside gps
Apr 26, 2010 | Northstar 6000I GPS Receiver
Moisture under screen
'standard' problem, condensation build up due to poor design planning... open the chart door for a few minutes and it will help balance the temp indifference between the inside and the outside (there is a little vent in there).
Feb 05, 2010 | Northstar 6000I GPS Receiver
My 6000i flashes No Engine Data
I researched my problem on the web, found several posts on various forums that helped. Bottom line, I determined that my 6000i installation did not include a gateway. I did that by eye balling the system after removing some panels.
Jan 30, 2010 | Northstar 6000I GPS Receiver
Northstar 600i locks up and at times you can't switch screens, turn it off or even turn it on. You have to wait and come back later to turn it off or on???
If you can delate all you log, waypoint routs or make a masterreset.
With a masterreset you will lose all data below
Sep 23, 2009 | Northstar 6000I GPS Receiver
Yes my northstar 6000i keeps losing gps signal
Aug 27, 2009 | Northstar 6000I GPS Receiver
Northstar 6000I GPS Receiver Logo
20 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
