Question about Hype Hy-525-bt Portable Mini Bluetooth V2.0 Pepper Speaker W/ 3.5mm
Hype mini bluetooth pepper speaker manual - Hype Hy-525-bt Portable Mini Bluetooth V2.0 Pepper Speaker W/ 3.5mm
Looking for the operating manual for the above model
[PDF]IBC233B Bluetooth Boombox - MCM Electronics
www.mcmelectronics.com/content/ProductData/Manuals/50-9770.pdf
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful ...
[PDF]Bluetooth Portable Boombox
static.bhphotovideo.com/lit_files/113971.pdf
4. Getting Started. Box Content. • 1x Bluetooth Speaker. • 1x USB Charging Cable. • 1x 3.5mm Audio Cable. • 1x Power Adapter. • 1x User Manual ...
[PDF]Boombox - Logitech
www.logitech.com/assets/.../ue-boombox-quick-start-guide.pdf
LogitechBoombox. Wireless Bluetooth® Speaker. Setup Guide. On your device ... Tap UEBoombox in the list of nearby. Bluetooth ... community of knowledgeable users.
[PDF]Getting started with Logitech® Mini Boombox
www.logitech.com/assets/42627/mini-boombox-qsg.pdf
LogitechAll other trademarks are the property of their respective owners. Logitech assumes no responsibility for any errors that may appear in this manual. ... When "Mini Boombox" appears on the device list of your Bluetooth device, select the.
Jan 04, 2016 | Audio Players & Recorders
How do I get a pairing code for a HYPE Ultra Slim Bluetooth Keyboard?
Pairing code for keyboard is not usually required. The one I have basically has a connect button, then you confirm on the computer. Otherwise the most common pairing code seems to be 0000.
Dec 01, 2014 | Hype Technology Ultra Slim Bluetooth...
How do I get a Bluetooth pairing code for a hype ultra slim Bluetooth keyboard?
The pairing code will be displayed on the screen of the device you are trying to pair it with. Simply switch on the keyboard. It should go into pairing mode looking for a device. Go into the bluetooth option on your device and you should see the "HYPE" device listed. Choose it and then enter the pairing code that displays on the screen of your device. That should be all there is to it.
Why does led flash blue then red constantly
Hello there,
From this download here
http://store.x-mini.com/upload/manuals/120416%20X-mini%20KAI%20Manual%20%28Eng%29.pdf
LED Battery Indicator
When charging:
Red - X-mini KAI Capsule Speaker is charging
Blue - X-mini KAI Capsule Speaker is fully charged
When in use:
Blue - X-mini KAI Capsule Speaker is turned on
Blue (dim) - X-mini KAI Capsule Speaker battery low
During playback through bluetooth, users will be alerted if
charging is required by a three-beep indication
If this is not right you will have to email them on support@xm-i.com
or if is in Warranty, get it repaired by the Seller.
Sep 16, 2014 | X-Mini KAI XAM11-B Bluetooth Capsule...
How stop the Bluetooth indicator always flashing on my Soundlink Mini?
Blinking blue light - Discoverable and ready to pair or reconnect with a device. See manual here: Bose SoundLink Mini Bluetooth Speaker Owner guide
Jun 16, 2014 | Bose Corp Bose SoundLink Mini
How long do i charge my hype HY-177 bluetooth speaker pod
Good luck charging. Based upon comments on other sites and my own experience, these items are sold with defective batteries.
Jan 03, 2014 | Hype Audio Players & Recorders
Need manual for hype audio bomb speaker
You are looking for the same thing I am instructions for the hype audio bomb speaker ?
Sep 09, 2012 | bomb-mp3.com Computers & Internet
How do you charge the bomb speaker
just get the USB cord (should come with the item you purchused) plug it into your computer then on the bottom of the bomb speaker there should be a little hole plug it into that.It should charge
Jun 19, 2012 | Hype Bomb Rechargeable Mini Portable...
How long do u charge The hype audio bomb when u 1st open it?
Charge 2-3 hours. Toll free for customer service is 1-888-867-0800
Jun 05, 2012 | Hype Bomb Rechargeable Mini Portable...
Hype Hy-525-bt Portable Mini Bluetooth V2.0 Pepper Speaker W/ 3.5mm Logo
111 people viewed this question
Top Hype Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hype Audio Player and Recorder Expert? Answer questions, earn points and help others
