Question about Broilmaster Premium P3 Grill
I am having difficulty installing the replacement burner
Can a zanussi cooker model number ZCG5000BKN be converted from NG TO LPG
You'll need to change all of the pilot light orifices to LPG size. You may have to replace the main oven burner assembly and the simmer burner/injector assemblies to accomplish this. (Essentially any part number with NG in the name should be replaced with the LPG equivalent.) The greatest difficulty may be finding the replacement parts, or paying for them; it may be more economical to sell the NG unit and purchase one already set up for LPG.
Jun 12, 2017 | Zanussi Kitchen Ranges
Propane Conversion Burner Turndown
It has to do with the diameter of th holes. The holes for natural gas are much bigger and this sounds like could definitely be your problem.
Thanks,
lee
Aug 04, 2008 | GE JGSP23 Gas Kitchen Range
Center control knob/burner
yes.. you can replace the burner... but you can still the burner for any possible dirt blocking the gas out on each hole...
micro
Jun 07, 2008 | Weber Genesis Silver B Grill
Vinpower Digital Vinpower Digital Burner- manual
Please explain what this term means: "copying audio tracks from computer memory". In normal operating you don't copy audio tracks you burn them to the disk using a compatible burning software.
May 15, 2014 | Vinpower Digital Computers & Internet
A technician is at my house trying to install a new igniter. He is having a problem. Can we get the instructions?
What igniter is trying to be replaced,is it for the surface burners or the oven and what difficulties are being encountered
Aug 11, 2011 | Thermador PRG304US Gas Kitchen Range
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
Glow plug lights but does not fire gas everything
This is most likely faulty gas valve coils. These electrical coils are located just above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If faulty, the gas valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
Front right element popped and started a fire...I replaced the element with a new one...I turned on the burner and nothing happens...is there a fuse for each burner? The other 3 burners are working...
Usually when a burner goes it is the switch that goes at the same time. There is a fusable link in the switch itself that blows, they are easy to replace. It is usually best to replace the recerptacle as well as the surge usually builds up a lot of carbon on the connectors and may cause some arcing and difficulty down the road.
May 18, 2009 | Electrolux 30" Self-Cleaning Freestanding...
Broilmaster Premium P3 Grill Logo
Top Broilmaster Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Broilmaster Grilling Expert? Answer questions, earn points and help others
