Question about Mackie Thump Series TH-12A 12" Two-Way Compact Powered SR Speaker -
How can i take apart mackie thump th-12a - Mackie Thump Series TH-12A 12" Two-Way Compact Powered SR Speaker -
3 Suggested Answers
bobhifi
  • 635 Answers
SOURCE: hi, I need to know how
After removing the back cover disconnect the tweeter cable form the terminal. Then hold the tweeter magnet and turn it anti clock wise. The driver unit will unscrew and come of the horn assembly.
Keep the driver unit on a firm table and unscrew the four + screws. It has a sandwich assembly which will part into two if you put a sharp knife and twist. You will see the tweeter diaphragm which can be lifted up again by using a sharp knife. The replacement diaphragm is available from the below given address
http://reconekits.com/tapcothumpth-15ahorndiaphragmpn0013252-1.aspx
Posted on Jul 04, 2011
palaboy
  • 5807 Answers
SOURCE: thump Th-12a powered monitor no power up
thanks for choosing Fixya for assistance.
Posted on Sep 11, 2012
Hi there, my relatively new Mackie Thump wont power up despite being plugged in / on etc. When I do with it on all i hear is a very low pop sound every 5 to 10 seconds or so
Your best bet is to contact Mackie Tech Support. Here is a link to their Suppot page. Mackie Tech Support
it's likely it needs to go to a repair shop. Here is a link to their service center finder. Mackie Service Center Locater
Feb 05, 2015 | Mackie TH-15A Active DJ Powered THUMP...
Mackie thump 15 a over load light stays on when powerd not even sending a signal to them.
There's a problem with the amplifier transistors or other heat generating circuit. That's what triggers the overload light.
Sep 11, 2014 | Mackie Thump 15 TH-15A Powered Speaker
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Mackie Thump TH-15A speaker amplifier module
Jose Miguel Carcamo Cruces do you have pictures of these j112 fet ? Thank you!
Oct 07, 2013 | Mackie TH-15A Active DJ Powered THUMP...
My Mackie Thump TH-15A will not produce any bass. I can get some sound but only from the top tweeter. Whats wrong and how can i fix this?
Could be the crossover has died or the main speaker winding has failed. Open her up and connect on side of the main speaker direct to a 9v battery and then wipe the other wire over the other terminal. If you get a crackling from the speaker then it's likely the crossover, if there is no response at all from the speaker then it is dead and possibly the crossover too.
Sep 23, 2013 | Mackie TH-15A Active DJ Powered THUMP...
How do i connect thump 15 A powered speaker to powered mixer?
You failed to give us the most important information... what brand and model of the mixer? Youwill use balanced interconnect lines to a balanced MAIN output jack, assuming it exists...
Aug 05, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Hi, I need to know how do you replace the 1" compression driver in a mackie thump th-15 and where would i get one from ? cheers.
Jul 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Bought a used Mackie TH-15A. When powered up there is no sound...at all.
The internal amp is in need of repair. Are there any other symptoms or signs?
Feb 08, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Mackie Thump Series TH-12A 12" Two-Way Compact Powered SR Speaker - Logo
122 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
