How to set day, date, time on Howard Miller world time touch alarm clock model 1054134
IB4G2008
  • 3587 Answers
SOURCE: Setting Time
ok..here it is, right from Fixya's manual pages..
click here
Posted on Feb 24, 2008
SOURCE: Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Posted on Sep 08, 2008
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
SOURCE: HSD128A projection clock came with chinese instructions
Here is the PDF of instructions. http://www.tinxi.com/download/88028_en.pdf
Posted on Jun 16, 2009
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Posted on Jul 03, 2009
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased an older Howard Miller clock and the clock is keeping time but pendulum is barely moving. What do I do?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick. Howard Miller Grandfather Clock
Dec 06, 2016 | Home
How do I adjust the settings on a 625-236 atomic clock
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
I hope this helps.
Oct 06, 2014 | Home
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
How do I change to Fahrenheit howard miller model 645706?
Go through the sequence of the time, date, month and then when it gets to the temp change it then
Aug 10, 2013 | Howard Miller 645-706 ANASTON ACCUTECH
My accuwave ds model 625-236 is stuck on the pacific time zone and will not let me reset it to EST which is where I live. How do I fix this problem. Thank you, Bhavna
Time Zone Setting
1. Press the MODE button to enter the Alarm Time Mode.
2. Press the SET button to change the time zone.
3. Press the MODE button to exit.
Apr 01, 2011 | Howard Miller Techtime II 625236 Clock...
How do you change the time
need owner's manual for Howard Miller Model 625-259 atomic wall clock.
Nov 08, 2010 | Howard Miller 645-627 Clock Radio
I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Apr 14, 2010 | Seiko Mantel Clock
I lost the instructions of my Howard Miller World Time 645-600 Travel Alarm Clock and I don;t know how to set my GMT. its always stuck on london..
Go to their web site "www.howardmiller.com/" and at the bottom of the page there is a menu.
At the bottom of the second column, click on "product manuals" and choose the one that suits your clock.
Feb 20, 2010 | Watches
How to change settings of Seiko world time alarm & desk clock
I have the user manual for this clock for anyone who sends me his e-mail address.....
indysandy@indy.rr.com
Feb 03, 2010 | Watches
292 people viewed this question
 Grubhead
Grubhead
