Question about Whirlpool GHW9400 Duet Washer
What year were they made - Whirlpool GHW9400 Duet Washer
How old is a 10 year old dog in human years
About 70, though it can vary from breed to breed.
Jan 07, 2017 | Dogs
Onkyo just shuts off...
check whether any loose connection in the board of the unit.
Aug 15, 2008 | Onkyo TX-SR605 Receiver
How to calculate the cost of equity
final value = principal value x (1+I)^n
I= interest rate for n say 10% it would be 0.10
if n= 1 year then interest rate if
one year interest rate so if 5 years n= 5
if interest rate is monthly then divide year int rate by 12
and increase n by 12 so 5 years equals 60 terms of interest calculation.
cost of equity would be pv + pv * CPI
if CPi was 2.5% as an example
cost of equity for year one= PV + (PV * 2.5/100)
fv = pv*(1+2.5/100)^1
if cpi is different each year then
fv= pv1(1+2.5/100)^1 + pv1(1+cpi2/100)^1 + pv1(1+cpi3/100)^1
If CPI is same for each year then FV = PV (1+0.025)^number of years.
^ 2 is like squared
Jul 20, 2016 | Furniture
Serial#854480 model94 Winchester rifle what year was it made
serial SI100808419 Samick guitar does it exist
Mar 11, 2012 | Computers & Internet
What is covered in the 100,000 mile/ 10 year warrenty for my 2004 optima
10-YEAR/100,000-MILE POWERTRAIN PROTECTION Covers repair or replacement of powertrain components (i.e., selected engine and transmission/transaxle components), originally manufactured or installed by Hyundai that are defective in material or factory workmanship, under normal use and maintenance. Coverage applies to original owner only, effective with 2004 model year and newer model year vehicles. On 1999-2003 model years, coverage applies to original owner and immediate family members (i.e., wife, husband, daughter, son, stepdaughter, stepson).
Second and/or subsequent owners have powertrain components coverage under the 5-Year/60,000-Mile New Vehicle Limited Warranty. Excludes coverage for vehicles in commercial use (e.g. taxi, route delivery, delivery service, rental, etc.).
5-YEAR/60,000-MILE NEW VEHICLE LIMITED WARRANTY Covers repair or replacement of any component manufactured or originally installed by Hyundai that is defective in material or factory workmanship, under normal use and maintenance.
The following components are covered for time and mileage limits indicated:
• Radio and audio systems (i.e., radio, compact disc player, DVD player, navigation system, and Bluetooth®): 3 years/36,000 miles
• Paint: 3 years/36,000 miles
• Battery: 3 years/unlimited miles (100% covered 2 years/unlimited miles; after 2 years and within 3 years, 25% cost of battery and 100% labor cost covered)
• Air conditioner refrigerant charge: 1 year/unlimited miles
• Adjustments: 1 year/12,000 miles
• Wear items: 1 year/12,000 miles (e.g., belts, brake pads and linings, clutch linings, filters, wiper blades, bulbs, fuses)
Mar 04, 2011 | 2004 Kia Optima
I would like some help in solving some TVM problems using the BA II Plus calculator. i.e. How to solve: I invested a lump sum of $2400 in an investment that returns 6% annually. How much will the...
2nd [CLR TVM] (clear TVM registers)
2 4 0 0 +/- PV ($2400 initial investment, negative because you're paying it out)
6 I/Y (6% annual interest)
1 N (one year)
CPT FV (compute future value, see 2544.00, the value after one year)
5 N (five years)
CPT FV (see 3211.74, the value after five years)
1 0 N (ten years)
CPT FV (see 4298.03, the value after ten years)
Feb 19, 2011 | Texas Instruments BA II PLUS Financial...
How to add current date to folder name- updates automatically
newPath = "C:\Year\" & year(Date)
Call MkDir(newPath)
newPath = "C:\Year\" & year(Date) & "\" & month(Date)
Call MkDir(newPath)
Apr 17, 2017 | Microsoft Visual Basic 6.0 for PC
HOW TO POST PAST YEAR ENTRIES INTO MYOB
You would have to post the entry as last financial year, just to keep it all ligit. After you have done so check that your retained years earnings are correct!.
Jun 30, 2009 | Myob Accounting Plus (BPJUBC00) for PC,...
Guranteeofasustekmotherboard
http://support.asus.com/service/service.aspx?no=231&SLanguage=en-us
Motherboard 3 Year Since 2000/1/1 onwards Notebook 2 Year Since 2002/2/1 onwards Portable PC (Degatto PC) 1 Year VGA Card 3 Year Since 2001/1/1 onwards (3 year warranty)
Prior to 2001/1/1 (1 year warranty) CD /DVD /CD-RW /DVD-RW Drive 1 Year Server 3 Year 3 year warranty coverage on ASUS' full system. Applicable only to components with genuine ASUS label sticker installed on ASUS Server. Warranty period is determined by the serial number on ASUS Server. Wireless Products 2 Year PDA 2 Year Since 2003/2/18 onwards
Dec 27, 2008 | Computers & Internet
C program
See the Following Program
Leap Years
Def: A year is a century year if it is divisible by 100.
Def: A year is a non-century year if it is not a century year.
Def: A year is a leap year if it is a non-century year that is divisible by 4, or a century year that is divisible by 400. Nothing else is a leap year.
In a source file named leapyears.cpp, write a program that will prompt the user for the starting year and ending year for a range of years and print to the screen all leap years in that range, 5 years per line. You must write a separate function called isLeapYear that takes a year as a parameter and returns whether or not that year is a leap year. Your main function will call the isLeapYear function in a loop for every year within the range delineated by, and including, the starting and ending years.
Help with Code Tags c Syntax (Toggle Plain Text)
  1. #include <iostream>
  2. using namespace std;
  3. bool LeapYear(int y)
  4. {
  5. return ( y % 4 == 0) && (y % 100 != 0) || (y % 400 == 0);
  6. }
  7. double isLeapYear(double x)
  8. {
  9. if( x > -10000 && x < 10000)
  10. return x;
  11. }
  12. int main()
  13. {
  14. int x;
  15. cout << "Please enter start and end of a range of years: ";
  16. cin >> x;
  17. if (isLeapYear(x))
  18. {
  19. if (LeapYear(x))
  20. cout << x;
  21. }
  22. }
The One More Sample Of the Program
C program to check whether a year is a leap year or not.
Code: C /*
** C program to check whether an entered year is a leap year or not
** @author: Pradeep
** @date: 02/12/06
#include<stdio.h>
int main(void)
int year;
printf("Enter the year: ");
scanf("%d",&year);
** The logic is that the year is either divisible by both
** 100 and 4 , OR its only divisible by 4 not by hundred
if(year%400 ==0 || (year%100 != 0 && year%4 == 0))
printf("Year %d is a leap year",year);
else
printf("Year %d is not a leap year",year);
return 0;
If Not Satisfied Just put the Program name in Google and Search
Sep 10, 2008 | Computers & Internet
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
