Question about BlueTrek Hummer Bluetooth Headset
How to pair bluetrek x2-2 - BlueTrek Hummer Bluetooth Headset
Have lost the manual to bluetrek and have an iphone 3 now and need to get the bluetooth working with this new phone
First, here is the link to the manual:
http://www.bluetrek.com/getfile.php?source=/download/product_download-manual63.pdf&filename=CompactClassic+Manual%2C+English&file_extension=pdf
Here are the instruction: 1. Switch on your Bluetrek and press and hold Talk button and Vol+ button for about five seconds untill indicator light flashes red and blue alternatively and you will hear a sound from speaker.
2. Open bluetooth in Iphone 3 search for bluetooth device. You will see Bluetrek Compact Classic. Click on name to pair and enter "0000" as pin code.
Bluetrek will be connected to iPhone.
Jun 02, 2011 | BlueTrek Compact Classic Ultra Slim...
I don't have the manual anymore and I forget how to pair the blue trek car kit with my phone. Please help!
Try this:
1. Put them close together
2. Switch on phone and select bluetooth discover mode (make sure it's visible to other devices)
3. Switch your BlueTrek device. Press and hold both Talk and Vol+ button for about 5 seconds until the indicator light flashes red and blue alternatively and sound can be heard from the speaker.
4. The phone should then detect the Bluetrek device. Follow the instructions from the phone to accept the pairing request. If you didn't change it, the PIN code should be 0000 (zeroes).
Hope this helps.
May 04, 2011 | BlueTrek Surface sound Duo Bluetooth Car...
How do i pair my bluetrek kr1 car kit (lost instructions
Just paired mine, think I pressed all 3 buttons at same time and 1234 was passkey
Feb 22, 2011 | BlueTrek KR1 Wireless Bluetooth Car Kit...
What is the password for my bluetrek mini
The Bluetrek Mini pairing password is “0000”, four zero. I found this pairing instruction from their website :
http://www.bluetrek.com/file/product-how_to_pair10.jpg
Hope this help!
Aug 08, 2010 | Cell Phones
I have anew phone and want to connect my Bluetrek X2 to it and the phone is asking for a password to connect the Bluetrek. Can you assist with the password.
Your headset's pairing code is '0000' (four zeros). By the way, if you happen to miss its user guide, feel free to download it from this location.
Hope you are able to sort your problems out soon.
Regards, Carlos
Jun 20, 2010 | BlueTrek G2 Consumer Headset
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
Password
The default password is "0000" four zeros. You can download the manual & pairing guide on the link below: http://www.bluetrek.com/support/g2/index.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | BlueTrek G2 Consumer Headset
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
communicate.
each other.
Jun 26, 2007 | BlueTrek G2 Consumer Headset
BlueTrek Hummer Bluetooth Headset Logo
44 people viewed this question
Top BlueTrek Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a BlueTrek Radio Communication Expert? Answer questions, earn points and help others
